Author Topic: Drive chain sprocket  (Read 3476 times)
Offline neat street
« on: August 28, 2013, 04:26:25 PM »
Hi All
Just started to do an engine strip, it will be slow coz I have other jobs on the go. I have taken a look at the front drive sprocket, and this seems loose but there is no adjustment. should this be a tight fit with no movement? (side to side movement approximately 4mm)
Many thanks for your input.
John
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline mick
Re: Drive chain sprocket
« Reply #1 on: August 28, 2013, 04:38:41 PM »
Hi john a bit of play is acceptable I think, not sure about 4mm, could be due to pattern sprocket ?, cheers  ;) Mick
Offline steff750
  • THE POWER OF DREAMS
« Reply #2 on: August 29, 2013, 12:21:52 AM »
 ;) yes same as mick says  no worries a bit of side play is ok just make sure the two securing bolts and locking washer are nipped up tight, even then the sprocket will feel a bit loose  ::)
Offline neat street
« Reply #3 on: August 29, 2013, 10:44:11 AM »
Hi Mick and Steff, thank for your help. I will probably need more advise soon?
Many thanks
John
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
Offline mick
« Reply #4 on: August 29, 2013, 11:20:20 AM »
No worries John ask away  ;) cheers Mick.
