Author Topic: Would like a longer side stand  (Read 4295 times)
Offline Warthog1959
« on: September 01, 2013, 09:30:38 PM »
Hi,
Does anyone know of a compatible side stand that is a couple of inches or so longer than stock. I have quite a Lean on my F2 and now I have fitted shocks that are 1" or so longer the lean is even more. Any other solutions appreciated.
Simon
Offline LesterPiglet
  • 1977 CB550F2
Re: Would like a longer side stand
« Reply #1 on: September 02, 2013, 04:50:05 PM »
Check the forks on the sidestand are not bent. Check the hole that the bolt goes through is not enlarged and finally check your sidestand isn't bent.  :)
Offline Warthog1959
« Reply #2 on: September 02, 2013, 08:50:18 PM »
Well there is some back and forward movement of the side stand even when the bolt is fully tightened. But not enough to require another 2" in length. This side stand is stubby to say the least.
No sign of any other bending.
What is the solution when the hole has enlarged? this frame has recently been powder coated.
  • 1977 CB550F2
« Reply #3 on: September 02, 2013, 09:18:14 PM »
I would think drill it larger and put a sleeve in.
Offline Green1
« Reply #4 on: September 02, 2013, 11:07:25 PM »
You don't need much play in the stand to get massive lean angles The bolt hole on my dads trophy is less than a thou over size and you have to place a two inch block under it to raise the bike to were it should be.Don't forget to check the condition of the bolt they can where quite a bit.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Warthog1959
« Reply #5 on: September 03, 2013, 06:58:33 PM »
Amazing really, Thanks, I'll give it my attention and see what happens. This forum is first class by the way, the knowledge base is huge.
Offline Yoshi823
  • Biker to the bone...
« Reply #6 on: September 04, 2013, 10:39:16 AM »
I fitted CBX1000Z forks & shocks to my CB750F2 & kept the standard sidestand without any problems. It did lean over more but not dramatically.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
