Author Topic: speedo tacho  (Read 3311 times)
speedo tacho
« on: September 25, 2013, 07:37:54 PM »
Hi Guys,
Got an old tacho and decided to have a go at it myself.It works well but the needle jumps about a bit.Managed to separate without crapping the ring but just wondered how the needle comes off and at early stages where to oil and what oil etc. Am I right in thinking the needle should just pull off?I know the USA site has had big discussions with this but I do find it a bit overpowering,Any advice welcome.
Bitsa
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: speedo tacho
« Reply #1 on: September 26, 2013, 02:23:05 PM »
Hi Bitsa,
Give the missus 50p / centimes & send her out to the flicks...
Get 2 of her best teaspoons, and put them opposite sides under the head of the needle, and gently pry the needle up. It'll come with a ping... but all should be well. Recently restored 4 instruments this way, no hiccups.
As for servicing the dashpots .... I guess drop kent400 a line.
Or try here, tho' I'm having probs accessing this site from Brunei @ the mo...
http://www.cb750faces.com/cb750faces.nl/en/
I personally never tackled these, but rather cautiously cleaned up what I could with ear bud / brake cleaning spray & then lubed the obvious bits with sewing machine oil. Happy so far..
Good luck.
Simon
« Last Edit: September 26, 2013, 02:33:38 PM by Lobo »
Offline mick
Re: speedo tacho
« Reply #2 on: September 26, 2013, 02:34:40 PM »
Here you go Bitsa try this  ;) cheers Mick. http://www.youtube.com/watch?v=AGzVLhMpky8
Re: speedo tacho
« Reply #3 on: September 26, 2013, 07:22:24 PM »
Cheers Guys worked a treat
Bitsa
