Author Topic: Knocking forks  (Read 12433 times)
Offline Ian DB
Knocking forks
« on: September 28, 2013, 06:39:54 PM »
My new (to me) CB500 K2 forks knock when you rock the bike backwards and forwards as if the forks are extending to their maximum and the damper rod is  hitting the top of the damper? I have stripped the forks, replaced the seals, refilled them with the correct amount of oil and added 10mm spacers between the top of the springs and damper rod lock nut, just for a bit of added preload as they seemed a little soft, and it still hasn't cured it. All in all the forks appeared to be ok when I had them stripped down.
Also I have noticed that when you rock the bike with the brake held slightly on, there as an amount of knocked that comes from what appears to be the free play in the pads/calipers. The pads are new and although the previous owner didn't smear the sides and back of the pads with silicone grease, I have now done this and also added shims on the top and bottom of the caliper pivot pin to remove any up and down play, the knocking still remains but is only slightly improved.
Having only ridden modern bikes until this getting this one its seems a bit strange.
Ian
Offline WPF81S
Re: Knocking forks
« Reply #1 on: September 28, 2013, 07:05:13 PM »
I suspect you need to adjust the headstock bearings. Regards Iain
Offline Ian DB
Re: Knocking forks
« Reply #2 on: September 28, 2013, 07:09:33 PM »
Hi Iain
I did that while the front end was stripped down, athough I have retained the original ball bearing arrangement for now as they also appeared to be in good conditon
Ian
Offline Green1
Re: Knocking forks
« Reply #3 on: September 28, 2013, 07:28:54 PM »
Hi Ian I had the same thing with my 750 sounds like your forks are in slightly twisted.Slacken everything don't forget the front mudguard and spindle.Do up the top yoke and then rock the bike back and forth with the front brake on and then do everything up again.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Ian DB
Re: Knocking forks
« Reply #4 on: September 28, 2013, 07:43:12 PM »
Hi Mick, Thanks for that, will give it a go and see how we get on.
Ian
Offline mick
Re: Knocking forks
« Reply #5 on: September 28, 2013, 08:44:52 PM »
Hi Ian let us know how you get on  ;) mines doing it on one fork leg think i'll give it a go to  ;) cheers Mick.
Offline Ian DB
Re: Knocking forks
« Reply #6 on: September 29, 2013, 10:29:35 AM »
Had a go this morning and no difference, easiest way to see whats actually happening is to pull back on the bars while its on the stand and the forks extend to their max and knock as I assume the damper rod is still hitting the top of the damper although its so hard to pin point where the clunk comes from.
There is no tension on the forks when the bike is on the stand and its easy to remove to top cap without fear of it shooting out of the fork tube.
Could it be that the damper and/or springs are shot? and would ATF oil instead of the 10-30's fork oil i've used?
There is no real knocking when rocking the bike backwards and forward so long as you hold the brake on hard. still knocks with the brake on slightly. This might settle down as the pads settle in?
Ian
Offline Green1
Re: Knocking forks
« Reply #7 on: September 29, 2013, 10:45:04 AM »
O yeah you just reminded me I changed my springs as they were about 10mm shorter then the min recommended length and that was what sorted it on the 750.Sorry I wasted your last half hour :-[ The top cap is now a pig to put in and it takes your eye out now when it's undone
It was my Triumph that was knocking because they were twisted.I seem to have a memory of a goldfish lately  ::)
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline Ian DB
Re: Knocking forks
« Reply #8 on: September 29, 2013, 11:42:16 AM »
No worries Mick, it was worth a try anyway. The springs are well within tolerance, but must be tired. Will look for replacements in due course.
Ian
Offline bomber
Re: Knocking forks
« Reply #9 on: March 01, 2014, 11:52:52 PM »
Any luck with the forks? Have you fixed it?
Mine where knocking on braking, it started after I took spacers out, think new springs are needed.
One step forward, two steps backward...
Honda CB550F 1976
Offline Ian DB
Re: Knocking forks
« Reply #10 on: March 23, 2014, 09:30:09 AM »
Hi Bomber, only just read your message, they are still the same, they only knock when rocking the bike backwards and forwards, its the damper rod hitting the top of the damper, which only happens when putting the bike on the centre stand and you then pull back on the bars thus extending the forks to their max. No issue on the road. Have now also got a complete set of spare forks which when i get round to overalling them will see if these do the same, my guess is its normal.
Ian
Offline Rob.b (Rob Birkett - RIP)
Re: Knocking forks
« Reply #11 on: January 18, 2016, 05:10:55 PM »
Hi.
Mine does exactly the same knock when the forks fully extend.
I would like to make it stop.
Rob
Re: Knocking forks
« Reply #12 on: January 18, 2016, 06:21:11 PM »
Sorry to upset you but a knock on "topping" is normal as it ain't supposed to happen that you lift the forks all the way up
Re: Knocking forks
« Reply #13 on: January 18, 2016, 08:28:49 PM »
Ah, interesting, and when I think about it I probably haven't owned a motorcycle with a mainstand other than the Honda for 30 years, so I will never have had the opportunity to bounce forks on any other bike than the Honda, which that probably explains why I have never felt the knock before.
 I suppose the way to stop it knocking is to stop bouncing it on the main stand.
Cheers for the post. Rob
Offline Seabeowner
Re: Knocking forks
« Reply #14 on: April 12, 2016, 07:14:31 PM »
Old subject. But just getting my 500K1 ready for its first MOT in 10 years. I have the clunky forks when putting the bike on the c/s. I had one of these back in 1974 and I don't ever remember the clunk. But I had just come from 3 years of Triumphs so maybe anything was an improvement.
Is it the damper rod clunking against its endstop when extended and has anyone had an issue at MOT? Testers don't like clunks, but as already said on the c/s is not real world.
thanks
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
