Author Topic: Carbs and jetting  (Read 5570 times)
Carbs and jetting
« on: October 28, 2013, 07:29:57 PM »
Hi all,
          Bit of info if possible, I am now going to be running a F2 engine in my K3.
I have a set of what looks like PD46B carbs with 90 main jets and as far as I can see 42 slow jets.
When I started the bike with the original engine it looked to be running weak.
Can anyone tell me if this set up will be ok, going to look at the float height is it 14.5mm for these carbs.
Regards,,
Re: Carbs and jetting
« Reply #1 on: October 29, 2013, 10:15:28 AM »
Engine size would help
« Reply #2 on: October 29, 2013, 01:05:14 PM »
Brian,
Sorry 550.
Offline peterengland
« Reply #3 on: November 16, 2013, 07:12:08 PM »
it seems you have the same set up as me, K3 frame with an F2 engine. My vin is stamped 1976 but by frame number it is a 77. Also got PD46A carbs but seems to be running fine so I will not fiddle!
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Offline Piki
« Reply #4 on: November 16, 2013, 11:03:18 PM »
I have 550K3 engine with F2 Head Engine running with PD46 Carbs, not problem with this configuration. 550 K3 running more "poor" that F models....but K3 are faster than F models!!!
« Reply #5 on: November 18, 2013, 12:16:28 PM »
Hi,
         I have sorted the issue, it was just down to the float heights.
Regards,
« Reply #6 on: November 19, 2013, 07:47:14 AM »
Sorry, missed your reply in the regulat trawling mate. If those are the K3 carbs float height and pilot jet cleanliness are most critical, at least Cirius in canada are making the push in pilots in a couple of sizes now
