Author Topic: Boyer Ignition on the SOHC 4's  (Read 4152 times)
« on: November 25, 2013, 04:57:36 PM »
I have a CB500-4,
 I have had it since about 1977,its an M plate,
 I have fitted Boyer ignition,its proved very good ,and reliable,
but , some thing that has happened twice in the past 25yrs is worth mentioning,
the general instalation is easy,
but over time,check the connection of the 2 wires on the sensor plate,
I have found the small screws that are the connections for the sensor coils becomes loose,giving poor starting and slow speed running,
 hopefully I have cured my issues using lock washers,
will let you know over the next 25 yrs
Offline Yoshi823
  • Biker to the bone...
Re: Boyer Ignition on the SOHC 4's
« Reply #1 on: February 01, 2016, 09:33:12 PM »
I replaced the complete points assembly on my CB750F2 back in the late 70s & spotted that where the blue & yellow wires attached to the laminate back plate of the BB ignition that there was apossibilty that they might come loose. So I loctited the connection so that it would never come undone with vibration  ;)
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
