Author Topic: front mudguard fit  (Read 9313 times)
Offline mickwinf
front mudguard fit
« on: December 01, 2013, 11:48:37 AM »
Hi all the 500/4 rebuild has stalled a bit due to no time or money but I did spend a bit of time the other day trying to fit the front mudguard. Problem is it is one I bought from ebay, in very good condition but seems to be slightly too big. Mountings fit fine to the forks but there seems to be a big gap between the tyre and mudguard, so much so I thought the front wheel or tyre was too small but its the same with a spare wheel I have. I could file the mounting holes to modify but don't realy want to, could it be a 750 item, I thought they were interchangeable.
Re: front mudguard fit
« Reply #1 on: December 01, 2013, 11:59:59 AM »
I thought both 500 and 750 used 3.25 X 19
 I have about 12mm side gap at max tyre width,
what tyre have you ?
Offline mickwinf
« Reply #2 on: December 01, 2013, 12:14:13 PM »
Its fine width wise its the height above the tyre that's the issue. tyre is 325/19 as standard. When I look from the side I can see the top of the tyre and a gap under the mudguard, have got a pic but not able to post it.
« Reply #3 on: December 01, 2013, 12:57:40 PM »
check the pic of mine,
http://www.sohc.co.uk/index.php?topic=5572.45
see how it compares
Offline mickwinf
« Reply #4 on: December 01, 2013, 03:23:33 PM »
cant tell for sure from photo but yours does seem to be similar to mine, I am sure my old one hugged the tyre more closely.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #5 on: December 01, 2013, 03:44:41 PM »
Here's my 550 to compare. Tyre is 100/90x19
« Reply #6 on: December 01, 2013, 04:46:43 PM »
 mine is as supplied in 1974,apart from extra disc,
Offline mickwinf
« Reply #7 on: December 01, 2013, 06:46:47 PM »
if I look at the same angle as Lester's I can see daylight between tyre and mudguard.
« Reply #8 on: December 01, 2013, 06:54:59 PM »
You probably CAN see daylight through yours, Lester's 100/90 front tyre is roughly equivalent to 4.00/4.10 in old money, so is a bigger tyre ;D
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
« Reply #9 on: December 01, 2013, 08:37:47 PM »
how d'ya get that photo on there lester ?
500K1 basket case for later
Offline mickwinf
« Reply #10 on: December 01, 2013, 09:15:25 PM »
trying pics
Offline mickwinf
« Reply #11 on: December 01, 2013, 09:16:25 PM »
no luck
  • 1977 CB550F2
« Reply #12 on: December 01, 2013, 11:42:41 PM »
I use www.photobucket.com
It's free. Just need to reg then upload to pbucket and share them anywhere.
Offline mickwinf
« Reply #13 on: December 29, 2013, 04:17:06 PM »
now we can post pics, look at this
  • 1977 CB550F2
« Reply #14 on: December 30, 2013, 12:23:22 PM »
Is that an original mudguard? Why no stays?
