Author Topic: oil bolt washer/crush washers  (Read 4879 times)
MIKE550/4
« on: January 01, 2014, 02:08:07 PM »
anyone give me sizes and sources for the above
wanted for front brake hoses, caliper to master cylinder ( m10?)
also crush washers and oil bolt washer is it the same thing
Re: oil bolt washer/crush washers
« Reply #1 on: January 01, 2014, 02:35:02 PM »
I use Copper washers bought for the brake lines on the banjos, or genuine Honda. If you can't get them local i can let you have some copper at cost plus postage.
Not sure what you mean by oil bolt, if it's the drain bolt Honda use a thick alloy washer which is good for several uses and I have not found a decent alternative
MIKE550/4
« Reply #2 on: January 01, 2014, 02:58:34 PM »
confused by what cmsnl call it ......no 19
http://www.cmsnl.com/honda-cb550k3-four-england_model14671/partslist/F05.html#results
but yes please bryan let me know via pm what you have and cost
thanks
Offline Ian DB
« Reply #3 on: January 01, 2014, 04:00:22 PM »
Hi Mike, if you dont get sorted via Bryan try Halfords, they do a 75 piece copper washer kit for £7.99, I've used them without any problems
Ian
Link :- http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_256973_langId_-1_categoryId_255228
« Reply #4 on: January 02, 2014, 06:11:46 AM »
Thats the washer on the banjo bolt on the brake line, let me know how many you need and i will work it out at the weekend for you
