Author Topic: Steering limit lug  (Read 3913 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Steering limit lug
« on: January 02, 2014, 08:19:56 AM »
Morn all,
One of the steering limit lugs is slightly bent - in a past life the bike (750K2) must have had a fall. Problem is, the yolk just touches the tank at left lock. Until now I've bodged it with a slip-on heater hose 'washer'  (which slips over the lug) - but time now to fix ... assuming relatively easy. Hmm...
Suggestions please?
Offline steff750
  • THE POWER OF DREAMS
Re: Steering limit lug
« Reply #1 on: January 02, 2014, 08:35:49 AM »
 yes I have had the same problem .I built mine up with a bit of weld and that's probably the limit of my welding skills as I tend to blow holes in most stuff  8)
Offline RGP750
« Reply #2 on: January 02, 2014, 10:21:27 AM »
How about drilling and tapping and putting a mushroom head screw in,shouldn't show too much.
 :D. You could increase with washers under in needed.
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: January 02, 2014, 12:51:08 PM »
An idea worth considering RGP.... not much material to drill into given a 'stout' mushroom would be needed, but will have an investigative look...
Aye Steff, your welding sounds like my painting, can never see why I shouldn't put 5 coats on at once and save time. Missus goes mad, everything (inc adjacent walls, carpets, curtains etc) about the house used to be a stipple finish - but hey, big result, she does the decorating now. Yahoo!
« Last Edit: January 02, 2014, 01:56:59 PM by Lobo »
Offline Seamus
« Reply #4 on: January 02, 2014, 05:04:42 PM »
Looks like a quick weld would be the best solution, Arc or mig to build up quickly and grind down to the correct thickness. As you say, not much to tap into.
Offline neat street
« Reply #5 on: January 08, 2014, 05:05:42 PM »
maybe drill and tap a small hole and put a screw in, you can maybe then adjust the screw to the distance out you need??
regards
John
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #6 on: January 15, 2014, 12:36:35 AM »
Thanks guys,
Thinking I'll go along with Steff / Seamus small weld plan: quite a bit of force at this point (potentially) and doubt a screw strong enough / don't want to weaken the lug further with holes.
Cheers for the various inputs,
Simon.
