CB350/400
400/4 Fork Seals
Topic: 400/4 Fork Seals (Read 4686 times)
Dundrod
Newbie
400/4 Fork Seals
January 18, 2014, 08:21:23 PM »
Just got a newish yokes and forks off ebay and had a hell of a job getting the seals off my original set had a look at the new ones and they don't appear too bad but any hints or tips before I start into them would be helpful thanks
Norniron
SOHC Expert
Re: 400/4 Fork Seals
January 18, 2014, 08:32:46 PM »
Are the fork seals ok on your new set?
1977 400 cafe
1972 500/4
2013 triumph STR675
Dundrod
Newbie
January 18, 2014, 09:33:07 PM »
They will need changing as its going to be a mix and match job my old tubes with the new fork legs and see which dampers and springs look good.On the old fork legs the retaining clips were rusty and the seals themselves were totally seized on the new fork legs I have nice bright clips and clean seals so I am hoping they will come out a bit easier really just wanting to know if anyone has any good tips before I start thanks.
January 18, 2014, 10:56:01 PM »
Undo the allen screw at the bottom BEFORE undoing anything else, if possible with a 1/2 drive key and air gun.
After that lots of cleanup and be VERY careful prizing out the ould seals to make sure you dont put a score up the inside of the sliders
CB350/400
400/4 Fork Seals
