Author Topic: What can i use to replace overflow tubes on carbs  (Read 6770 times)
Offline MikeM
« on: January 20, 2014, 01:22:10 PM »
2 of mine are cracked and split   ::)
Re: What can i use to replace overflow tubes on carbs
« Reply #1 on: January 20, 2014, 04:31:37 PM »
Try Planet silicon, they do a full range of Nitrile pipe. You are talking about float bowl drain hose?.
« Reply #2 on: January 20, 2014, 04:36:54 PM »
If you mean the brass tubes  its a mechanical nightmare problem, if you mean the rubber overflow try injector pipe overflow tube or vacuum advance tube at a motor factors
« Reply #3 on: January 20, 2014, 07:07:17 PM »
As Bryan says most motor factor places stock this I actually got some here in cabbage ville.Just take one with you easy pezee.
Bitsa
Offline MikeM
« Reply #4 on: January 21, 2014, 01:52:53 PM »
just the rubber overflow tubes, pretty sure the tubes "inside " are fine
« Reply #5 on: January 21, 2014, 05:29:43 PM »
As i said Mike, try planet Silicon. 1 meter is about £3 with free post. While your looking get yourself new fuel lines and breather drain hose.
Offline MikeM
« Reply #6 on: January 21, 2014, 08:02:18 PM »
im on it guys thanks again
« Reply #7 on: January 21, 2014, 08:35:22 PM »
Mike, fuel pipe is 5.5 and breather is 12mm. Off the top of my head can not remember carb overflow size.
« Last Edit: January 21, 2014, 10:01:09 PM by trigger6969 »
Offline MikeM
« Reply #8 on: January 22, 2014, 02:02:25 PM »
does this look right
fuel line 5.5 by 10.5
http://www.ebay.co.uk/itm/140685400102?var=440175994842
carb drain lines
I am guessing 4mm internal by 8mm
http://www.ebay.co.uk/itm/161145097263?var=460229641099
breather pipe all from same company could I use this
11mm is nearest I could find..... really not sure this is correct
http://www.ebay.co.uk/itm/130740225601?var=430086075659
