Author Topic: refitting this part  (Read 5323 times)
Offline MikeM
refitting this part
« on: January 20, 2014, 01:38:13 PM »
Having problems with refitting a part  no 15
currently my no 15 and 12 are joined, as they came off the bike, do they have to be separated to get it back on and be able to slide the spindle through ?
Offline LesterPiglet
  • 1977 CB550F2
Re: refitting this part
« Reply #1 on: January 20, 2014, 02:21:45 PM »
I've only done it when they are separated. Don't know if it can be done otherwise.
Offline MikeM
« Reply #2 on: January 20, 2014, 02:39:05 PM »
thanks so if I separate is there still enough room to clear  that bracket on the swingarm ?
« Reply #3 on: January 20, 2014, 04:35:20 PM »
I think you need to fit them before fitting the swing arm mate
« Reply #4 on: January 20, 2014, 04:41:47 PM »
Part number 15 should be fitted before the swinging arm. I took one off a couple of days ago, but i was taking the swinging arm off. You could try popping the rear shocks off and see if dropping the swinging arm down will give you enough room. The shocks will have to come off anyway.
  • 1977 CB550F2
« Reply #5 on: January 20, 2014, 06:45:42 PM »
Remove the wheel, detach the shocks and push the swinging arm up and you should be able to fit it.
« Reply #6 on: January 20, 2014, 07:08:46 PM »
Agreed with all
Bitsa
Offline MikeM
« Reply #7 on: January 21, 2014, 02:00:12 PM »
thanks looks like a slight dismantle then........
