CB350/400
400/4 Front Mudguard
Topic: 400/4 Front Mudguard (Read 7108 times)
Drew400
400/4 I restored
January 28, 2014, 03:45:56 PM »
My 400 has a front mudguard with only one pair of support struts behind the fork leg. All the pictures I've seen of 400/4s have two pairs of struts supporting the mudguard, i.e. one pair in front of the fork leg too. I'm guessing that mine is an after-market part, especially as there is no evidence of tampering or that more supports we're ever present. Expert advice much appreciated, thank you. Drew.
LesterPiglet
1977 CB550F2
Re: 400/4 Front Mudguard
January 28, 2014, 04:58:51 PM »
I found this
from here
http://www.motorera.com/honda/h0400/four.htm
No other info I'm afraid.
Trigger
January 28, 2014, 05:09:11 PM »
Do not worry Drew, some do, some don't. I have seen many with only one strut. I have a CB550 with one.
LesterPiglet
1977 CB550F2
January 28, 2014, 05:29:25 PM »
I'll do you a swap.
Last Edit: January 28, 2014, 05:31:48 PM by LesterPiglet
hairygit
January 28, 2014, 05:36:13 PM »
It's probably original, the CB750F1 started life with 1 brace, and part way through production it changed to 2 braces
Clem2112
Midlife
SOHC Expert
CB400F1 1976 R1200GS 2016 Matchless G80 1955
January 29, 2014, 05:01:39 PM »
Think the UK 400/4 always had front and rear stays - F, F1 and F2
Many U.S. Bikes seem to have just the rear stay type.
Drew400
400/4 I restored
January 29, 2014, 06:16:32 PM »
Thank you all. I'll stop worrying about its originality and start worrying instead about the cost of fettling! Cheers, Drew.
Piki
SOHC Expert
January 29, 2014, 06:45:24 PM »
I think that the originals have two stays. The originals has stamped on the bottom 370(on the middle of front guard).
Lobo
Lobo
Lobo
January 30, 2014, 01:53:29 AM »
Drew,
From the Honda 400F parts manual... your mudguard is correct.
This is a late American F2 spec. (the 'A' implies American spec)
Simon
ashewan
Newbie
February 01, 2014, 11:26:20 AM »
Hi,
I've only put the rear strut on my front mudguard, although the mudguard is drilled for the front strut as well.
Its also drilled to take the vertical style front number plate which might explain the need to add the extra bracing at the front.
Drew400
400/4 I restored
Reply #10 on:
February 02, 2014, 03:34:47 PM »
Thank you all again, especially Simon... parts manual picture, hmmm, very impressive! I now need to clean off all the crap to see if I can find '370' somewhere.
I'm now moving on to my next query which I'm guessing web chat protocol requires me to start anew. So, I think it's time to close off this particular query.
Cheers, Drew
CB350/400
