Chain slop?
Topic: Chain slop? (Read 4461 times)
peterengland
SOHC Member
Chain slop?
February 03, 2014, 06:18:24 PM »
I have noticed a slight 'slop' noise that sounds like chain when on light throttle (eg: roundabout in 3rd) it seems to be in unison with the rotation of the drive chain but disappears under more load but when I check the chain and move it up and down as far as it will go it touches nothing.
Any ideas?
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
LesterPiglet
1977 CB550F2
Re: Chain slop?
February 03, 2014, 06:22:50 PM »
Get the rear wheel off the ground, rotate it and check the chain for tight spots.
peterengland
SOHC Member
Re: Chain slop?
February 03, 2014, 06:26:52 PM »
I did that the other day and lubed the chain at the same time but didn't notice any but will have a more detailed look.
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
peterengland
SOHC Member
Re: Chain slop?
February 04, 2014, 05:12:36 PM »
Sorted! it was just simple adjustment, there was more play in the chain than I thought but I still can't understand why it touched nothing when I moved it up and down as far as it would go.
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Trigger
Re: Chain slop?
February 04, 2014, 05:29:17 PM »
I have been playing with a weird chain on a 1985 Suzuki GSX-R. The chain kept going tight and getting noisy. Even after a new chain & sprocket kit fitted,and adjusted.It sill went tight. It turned out to be a lot of access play in the swing arm.
Chain slop?
