Author Topic: my latest problem  (Read 5665 times)
Offline MikeM
my latest problem
« on: February 07, 2014, 07:40:23 AM »
going  to fit the rear guard and notice powdercoaters have just powdercoated over the bolts that hold the rear guard on
stuck in their fast... no problem  just remove the bolts and use new ones
well no there stuck fast... contacted powdercoaters and they dont want to know
so any tips to remove the bolts out of rear mudguard ?
thanks
Offline cb750stu
Re: my latest problem
« Reply #1 on: February 07, 2014, 07:45:50 AM »
Hi,
I had the same problem so I used a Stanley blade to carefully cut around the bolt then carefully back out the bolt I think this helps because if you just back off the bolt the PC will crack,
I don't bother any more with plugging the holes with old bolts I just tap the holes out afterwards ,
Cheers Stu
1976 CB750 F1 SS in bits !!! but getting there
Offline MikeM
« Reply #2 on: February 07, 2014, 07:54:59 AM »
Problem i have they have powdercaote the bolt as well, went to try and remove and one bolt part of it sheared off, its like its set rock hard and now part of the guard... will put a pic up later to show
lesson is remove everything first..... would have thought they would have known this though
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: February 07, 2014, 08:45:22 AM »
Are the bolts screwed fully home? If not try tightening them first.
Offline MikeM
« Reply #4 on: February 07, 2014, 09:21:13 AM »
Imagine the head from underneath with  the thread sticking through with no nut on it, totally will not move
Offline MikeM
« Reply #5 on: February 07, 2014, 09:39:02 AM »
You can just about make out the bolts on rear guard , they have been powdercoated in from underneath and the top and they are well jammed in
Offline MikeM
« Reply #6 on: February 07, 2014, 12:03:15 PM »
does acetone remove powdercoat ?
used in nail profession ?
  • 1977 CB550F2
« Reply #7 on: February 07, 2014, 03:11:21 PM »
Put a heatshield between the nut heads and guard and torch them.
« Reply #8 on: February 07, 2014, 04:00:48 PM »
If the thread sticks out underneath and has been coated you need to grind/cut off the thread that is showing then they may move
Offline totty
« Reply #9 on: February 07, 2014, 06:59:40 PM »
Aren't they welded in studs? They are on mine. Just take a die or thread file to them to clean the powder coat off the threads, cut round them with a stanly knife first to stop the power coat cracking away.
Offline MikeM
« Reply #10 on: February 07, 2014, 08:45:16 PM »
I think they are welded from underneath, both of the studs are cracked
they look like bolts with a flat head .( the flat head sits underneath) they are going to have to come off and replaced as they are totally shot, I can see a big crack going up both of them
would I get away with cutting the thread off drill out the rest and replace with bolt and nut ?
Offline totty
« Reply #11 on: February 07, 2014, 09:00:02 PM »
Yes that would work.
Offline MikeM
« Reply #12 on: February 07, 2014, 09:19:25 PM »
Will give it a go.... is it not standard practise then when powdercoating to cover up threads ?
Offline Green1
« Reply #13 on: February 08, 2014, 06:50:21 PM »
You would think so but they normally coat over any bearings,bolts and anything else that gets left in.
I did read somewhere that methanol removes powder coat Good luck
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
