Author Topic: Cb750 k3 headlamp and ring mount wanted  (Read 5773 times)
« on: February 10, 2014, 08:59:42 PM »
Guys - anyone have a half decent k3 headlight and ring mount available to buy (basically the whole lamp and ring assy to bolt into the headlight bucket). ?
James.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Cb750 k3 headlamp and ring mount wanted
« Reply #1 on: February 11, 2014, 08:44:35 AM »
James... being lazy & not done any research... but this any help?
http://www.ebay.co.uk/sch/Motorcycle-Parts-Accessories-/14780/i.html?_from=R40&_nkw=headlamp&rt=nc
Simon
« Reply #2 on: February 11, 2014, 08:57:13 AM »
You taking the piss simon? :-). Looking for the correct honda setting ring / mount and a genuine lens / lamp if possible.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Lobo
« Reply #3 on: February 11, 2014, 09:23:28 AM »
Na... as I mentioned, was being lazy as quickly came across the website & posted it without investigating.
My fault for trying to help...  will do better next time!  ;)
« Last Edit: February 11, 2014, 09:36:04 AM by Lobo »
« Reply #4 on: February 11, 2014, 01:42:17 PM »
Sorry mate I completely got the wrong end of the stick there - thought you were calling me lazy ha ha. Thanks for the link - have had a good search on ebay but not yet seen anything suitable. Thanks again, James.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #5 on: February 11, 2014, 02:12:20 PM »
Did indeed spot a couple of reasonably priced Stanley units (no ring) in the 'States... but jeese, the postage! And then the bloody tax...
Good luck anyways,
Simon
Offline mickwinf
« Reply #6 on: February 11, 2014, 02:51:37 PM »
Is the headlamp the same as the 500/550 as I might have one, not sure of condition though. Does it have a sidelight holder in the reflector as US bikes usually don't. Also Silvers have repro items which I found good quality.
« Reply #7 on: February 11, 2014, 03:56:12 PM »
Good spot oddjob thanks for that - have made an offer on the german Ebay one.
« Reply #8 on: February 11, 2014, 05:33:16 PM »
Be careful buying headlight units from abroad, don't forget they drive on the wrong side of the road, so the headlight dips to the RIGHT instead of the left as UK vehicles do, and will FAIL the M.O.T, so check which market it is for before wasting your hard earned cash!:))
Sent from my GT-S5839i using Tapatalk 2
« Reply #9 on: February 11, 2014, 09:09:28 PM »
Yes.
Most views are correct the only difference instaed off the adjusting screw being on the left,right is the same if you are lucky enough to get either, all you have do to do is drill a hole the opposite side for you no big deal.Original stuff as we all know has worst odds than the lotto,so get with it grab it b4 you lose out if you want original
Bitsa
« Reply #10 on: February 11, 2014, 11:33:13 PM »
Thanks Bitsa - pulled the trigger on it and like you say I should be able to modify the adjuster mechanism if necessary. Thanks for the steer oddjob. James
« Reply #11 on: February 12, 2014, 06:51:20 AM »
I'm sure you'll find it's more than just the adjusting screw, the fluting on the glass is what determines which way the lamp dips, the only way round it is to stick black tape over certain areas of the lens (ask Steve D, he has to do it with his!) and if an original look is what you want, black tape will just not look right!:-\
« Reply #12 on: February 12, 2014, 09:32:46 AM »
Fair point - maybe i'll just move to france ;-)
