rear brake light spring
Topic: rear brake light spring (Read 4022 times)
MikeM
SOHC Expert
March 11, 2014, 10:26:33 PM »
putting the rear brake light spring on, have attached to eye on the switch, was expecting to see a tab on brake arm but none there, does not look like its broke off or anything
where does the k3 spring attach to then ?
LesterPiglet
1977 CB550F2
Re: rear brake light spring
March 12, 2014, 09:28:46 AM »
On the inside of your brake spindle thingy the lever attaches to is L shaped. You will see a notch in it. Spring connects to this.
http://www.cmsnl.com/honda-cb550k3-four-england_model14671/partslist/F18.html#results
Last Edit: March 12, 2014, 01:58:41 PM by LesterPiglet
