Author Topic: fork drain screw bolt sheared  (Read 31699 times)
Re: fork drain screw bolt sheared
« Reply #45 on: March 27, 2014, 09:42:12 PM »
Hi Trigger, I had assumed from Mike's last post that he had ordered a kit but couldn't get a kit with Dx1.5 coils:))
Sent from my GT-S5839i using Tapatalk 2
Offline MikeM
« Reply #46 on: March 27, 2014, 10:10:04 PM »
thanks all
just bought the 8mm kit , no big deal I will order the 9mm coils as well,  great fun this drilling lark  :-\
« Reply #47 on: March 27, 2014, 10:29:30 PM »
Sorry, Hairy. I am getting lost here Mike. Why have you ordered a 8mm helicoil kit when the oil drain bolt is 6mmx10mm? When you say 8mm do you mean the length???
« Reply #48 on: March 28, 2014, 07:27:19 AM »
Get a cheap set of "rats tail" files as if there is any coil left outside after fitting to full depth you use the triangular file to put a notch in the coil wire at the edge of the hole and break off the excess---hope that makes sense asit's a damn site easier to do than explain
Offline MikeM
« Reply #49 on: March 28, 2014, 07:48:00 AM »
http://www.ebay.co.uk/itm/25-Piece-Helicoil-Thread-Repair-Kit-M6-x-1-0-x-8-0mm-/310678382294?pt=LH_DefaultDomain_3&hash=item4855dfe6d6#ht_1761wt_952
what I have ordered  ;D
m6x1x8.......... could not find a 9mm kit but hairygit gave me link to the coils....... and tap is in the kit
« Reply #50 on: March 28, 2014, 08:34:05 AM »
Mike, I use helicoils nearly every day. The kit you have ordered is spot on, there is no need to order extra coils. The 8mm in length will coil to 9mm once in a thread. There is no such thing as a 8mm in length. It will be a thread of 6mm x 1mm pitch at 1.5D. The 1.5D is the depth of the coil, so the seller is giving you the depth measurement before insert.
It is a bit like the washer suppliers saying that they are selling a M3 washer but, in fact has a ID of 3.2,  M6 washer which has a ID of 6.4 and a M12 has a ID of 13mm. A true washer that has a ID of 6mm, would never fit a 6mm bolt, because there would be no clearance.
Helicoil kits do not come with a tap wrench. Do not go out and buy one. Once you get the kit PM me and i will post you a wrench and you can use it and then post it back to me.
Offline MikeM
« Reply #51 on: March 30, 2014, 02:10:11 PM »
turning into a disaster  :-[
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
« Reply #52 on: March 30, 2014, 10:26:28 PM »
's happnin mike ?
500K1 basket case for later
Offline MikeM
« Reply #53 on: March 30, 2014, 11:04:37 PM »
off centre by a touch, drill bits snapped and drilled the casing....
time for a break from it
Offline MikeM
« Reply #54 on: March 31, 2014, 08:01:09 PM »
drain from top time
what are chances of replacement case covers,
Offline matthewmosse
« Reply #55 on: March 31, 2014, 08:13:11 PM »
blob of weld onto the broken off remains, then grip the bit of weld with mole grips. I might be able to dig out a spare fork leg lower / set of if you get stuck.
Offline MikeM
Re: forks taking out scratches
« Reply #56 on: April 11, 2014, 04:50:44 PM »
ok so think I have sorted the sheared drain bolt,
  any tips for taking out scratches on the forks, not really deep but enough to feel them and see them
« Reply #57 on: April 11, 2014, 05:41:34 PM »
Scratches, with wet & dry. By the look of them you need to start with 400 and work up to 2,000. Then out with the polisher, to a nice finish.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #58 on: April 11, 2014, 06:29:00 PM »
A nice chrome or stainless allen screw is a good replacement for that drain hex.
Offline MikeM
« Reply #59 on: April 11, 2014, 07:33:24 PM »
yeah will go for the stainless allen
fork seals should arrive tomorrow so will clean up cases best I can, then get it all back together and start it ?
