Author Topic: Found my "points" problem.  (Read 5645 times)
Offline LesterPiglet
  • 1977 CB550F2
« on: March 15, 2014, 06:04:04 PM »
As an addendum to this thread http://www.sohc.co.uk/index.php?topic=6299.0 I've found out the problem was not the points at all but the HT leads.
The heatshrink had broken down on the inner two cylinders and was causing intermittent sparking. I hadn't discovered this because I was troubleshooting in the dark with the use of a 200w halogen lamp. Daylight came and the bike was in the shade and I noticed the arcing. All sorted now thank goodness.
Offline mickwinf
Re: Found my "points" problem.
« Reply #1 on: March 15, 2014, 07:13:48 PM »
Glad its sorted mate
  • 1977 CB550F2
« Reply #2 on: March 15, 2014, 08:00:54 PM »
Thanks. It feels good to overtake scooters now.   ;D
« Reply #3 on: March 15, 2014, 08:09:53 PM »
So that was a pointless problem then Les :) :) :) :)
« Reply #4 on: March 16, 2014, 11:40:03 AM »
glad its sorted,
 I wish the HT leads could be renewed as a complete length ,instead of joining,
 they are getting on for 40yrs old,and starting to break down,
 any suggestions ?
« Reply #5 on: March 16, 2014, 12:02:16 PM »
Yeah it's a bit of a pain John. Not ideal, but guess you're aware of the ngk splicers? http://www.ngksparkplugs.com/products/performance/splicers.asp?mode=nml
« Reply #6 on: March 16, 2014, 02:50:40 PM »
 thanks,
 but I would prefer to fit into the coils,not just join to old cable,
 I have done joins using thin woodscrews and sleeving,its working so far !!
« Reply #7 on: March 16, 2014, 03:06:11 PM »
In my experience you've got very little chance of successfully opening the 'moulded' body of the coil and successfully re-sealing it afterwards. Also, it's normally the 'cut end' of the ht lead that starts to degrade - I've found that when you cut and splice close to the body of the coil the original ht lead is 99% of the time in excellent condition. The ngk splices are excellent quality. Just my view, James.
  • 1977 CB550F2
« Reply #8 on: March 16, 2014, 04:41:11 PM »
My homemade splices are still fine after 30 odd years. There is no movement of the leads up near the coils so I'm not expecting any problems.
I used silicone leads that are very flexible.
« Reply #9 on: March 16, 2014, 05:11:26 PM »
yep fair point...
« Reply #10 on: March 16, 2014, 05:42:55 PM »
