Author Topic: All balls head bearings  (Read 3956 times)
Offline Norniron
« on: March 16, 2014, 09:36:15 PM »
Has anyone fitted these tapered head bearings to their 400/4.
I was wondering whether to use the packing washer for the base bearing?
I was worried that the yokes might miss the turn stopper on the frame.
The yokes are in the freezer at the moment to contract them,so when i fit the base bearing you only get one go at it.
1977 400 cafe
1972 500/4
2013 triumph STR675
Re: All balls head bearings
« Reply #1 on: March 16, 2014, 09:40:56 PM »
What is wrong with ball bearings??? The money you saved from your parts order will by a few ball's.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: March 16, 2014, 11:28:36 PM »
I had mine in and out 3 times before I got it right. My bearings came with 2 different sized spacers.
ka-ja
« Reply #3 on: March 17, 2014, 08:57:24 AM »
Hi,
     Single spacer at the bottom under the bearing journal, it stops the bottom yoke fouling the steering lock/headstock---ken
