Author Topic: carb needle position  (Read 5013 times)
Offline RGP750
« on: April 01, 2014, 06:57:39 PM »
Cleaned carbs up and now to fit all of the new bits.
The needle is set at the second notch up,anyone know
if that is the standard setting.
cheers Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline Norniron
Re: carb needle position
« Reply #1 on: April 01, 2014, 07:28:50 PM »
They are normally in the centre notch
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline RGP750
« Reply #2 on: April 01, 2014, 07:39:28 PM »
with most other bikes i have put them in the centre. The bike is going to have a 4 pipe system
 it was running on a motad 4 into 1,Would it have been changed because of that although i thought only jets may be changed.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline mick
« Reply #3 on: April 01, 2014, 09:18:39 PM »
I would put in the middle setting and alter the jetting , on my F1 I was running a homemade 4into1 & s&b filters and jetted up to 125 main jet,  ;) cheers Mick
Offline Waggles
« Reply #4 on: April 02, 2014, 11:05:59 AM »
Motad 4 into ones shouldn't need any carburation changes, my F1 is running one with standard jetting and centre notch needle position. I have standard airbox / filter.
Strange yours was in second notch, that would richen mixture over throttle range 1/4 to 3/4 approx. perhap p.o. was being cautious? or had non standard filters?
Offline RGP750
« Reply #5 on: April 02, 2014, 11:53:14 AM »
would you  think it should be on the centre for standard pipes then?
Last time i took it out my son was following and said he thought it smelled rich.
The exhaust valves do look very sooty. How much of a nightemare is lifting the head
and cleaning and reseating the valves,done it several times on British twins.
The engine is out of the frame.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #6 on: April 02, 2014, 02:47:31 PM »
RGP,
Got this off sister site but I have always thought like the others middle setting.I have now put mine on the 4Th and looking at the plugs ain't made any difference.Still goes good ticksover and runs real sweet.Don't know!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Bitsa
