Author Topic: before i start this bike  (Read 5892 times)
Offline MikeM
« on: April 14, 2014, 09:47:34 PM »
ok getting ready to start this bike
this bike has sat since approx. 83
last on road sept 83
sentimental reasons for rebuild which I wont go into now but what are must dos and donts before I start
Offline MikeM
Re: before i start this bike
« Reply #1 on: April 14, 2014, 09:52:07 PM »
before I started this bike never worked on a bike
I have done to recap
top end gasket rebuild
carbs cleaned and new jets
back to standard airbox
wheel bearings changed front and rear
fork seals changed
tank flushed
new throttle cables
new piston caliper, new pads
earth points cleaned and grounded at coil, side of engine and rear mudguard
there is loads more but cant remember
oil is yet to be put in along with fresh petrol
main concern is lack of oil around engine
wiring all connectors cleaned, new rectifier and regulator
« Last Edit: April 14, 2014, 09:53:39 PM by MikeM »
Offline Paull
« Reply #2 on: April 14, 2014, 10:10:42 PM »
Hi MikeM,
You could take the plugs out remove rocker cover and turn the engine over BY HAND to make sure your getting oil up to the top of the engine.
Paul
S**t Happens
« Reply #3 on: April 15, 2014, 08:59:31 AM »
I've always done by hand (but then I wasn't running a business)
If you take the plugs out and crank by hand (or foot) until the oil lamp goes out.
Very satisfying...    :)
« Reply #4 on: April 15, 2014, 06:48:13 PM »
I have always built engines with Graphogen , so no worry's turning the motor over on the start button. I find just leaving a couple of tappet caps off to see if the oil is reaching the top end.
« Reply #5 on: April 15, 2014, 09:54:55 PM »
Graphogen is great stuff. You can even do a bench start & run test without oil. Beds in the parts a treat. Never used STP, but i think it was for you older boy's. ;)
