Author Topic: what is best fastener option for joining mudguard to its bracket  (Read 1849 times)
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
Hi, looking for options for rejoining my front gaurd to its bracket. Original looks loke it uses chromed rivets.. are these available anywhere and if so are they easy enough to use ?  ... or is it better / easier just to go with dome head bolts
500K1/550K3 mongrel cafe racer project for now at http://www.sohc.co.uk/index.php/topic,4120.0.html
500K1 basket case for later
Re: what is best fastener option for joining mudguard to its bracket
« Reply #1 on: May 21, 2014, 09:34:18 AM »
Could you get standard SS cap screws and grind the heads to domed shape domed then polish to look like chrome?
« Reply #2 on: May 21, 2014, 09:45:20 AM »
You can buy round head stainless cap screws just use those
« Reply #3 on: May 21, 2014, 03:28:21 PM »
Agreed Bryan, as long as you don't mind the hex hole in the top (depends if you want it to look like standard or not
Cheers,
Ash
Offline Ewan 500 K1
« Reply #4 on: May 21, 2014, 07:25:36 PM »
thanks guys ... its great to bounce things off the forum when the grey matter's failing....likin the dome nut on the outside and would be able to get chrome ones at custom fasteners.
... but then again maybe they are a bit chunky an only appear to be available in stainless.
Might be trending towards flange head dome bolts (top photo) or Flange Button Heads (middle photo) or Plain button heads. ( bottom photo) Plain button heads probs a bit small diameter , so reckon a flange button... matches all the stainless allens all over the shop.
Plain bog standard alloy rivets was my default and that would have looked rubbish.
« Last Edit: May 21, 2014, 07:29:45 PM by Ewan 500 K1 »
