Author Topic: Battery cable size?  (Read 4889 times)
Offline MarkCR750
Battery cable size?
« on: June 01, 2014, 05:34:34 PM »
Can anyone tell me what size/amperage battery cable I need, I'm fitting the battery under the seat hump but the starter solenoid will be at the rear of the fuel tank so the run from the battery to solenoid will be a little longer than standard.
Also does the earth cable have to go to the RH engine mounting bolt as it does on the standard K7, or will anywhere on the frame be ok?, cheers Mark.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Re: Battery cable size?
« Reply #1 on: June 01, 2014, 07:37:13 PM »
Given that length of run Mark, I'd use the largest cable you can fit in the gap.
Tip: check out welding cable as it is very flexible. I used it on some jump leads I made up (you can't buy bike jump leads and the car ones normally have massive croc clips!
Sent from my iPhone using Tapatalk 2
Offline MarkCR750
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: June 02, 2014, 12:52:27 AM »
Hi Mark,
170A cable should be OK, noting that the CB750 starter typically draws 120A ... but 280A at stall.
Take care if simply earthing to a frame point... as all of those above 120-280 amps will have to pass through this connection on their way into the frame... and thence through the various engine mount bolts & to your starter. (which is using the engine casing as an earth)
For my money, you'd be better, if possible, doing it the Honda way & choosing a nice big bolt which goes through a very solid frame point & also (electrically) bonds the engine casing. Wherever you decide to attach this, -bearing in mind the loads it carries.. scrape away all paint etc & get the connections down to bare metal. Don't pick any bolt which goes through vibration mounts - as these will insulate any current from flowing.
If a good connection is not made you run the very real risk of melting your loom (earth) down the track... see the photos as posted on this forum about a year ago.
Cheers.
« Last Edit: June 02, 2014, 02:39:41 AM by Lobo »
Offline MarkCR750
« Reply #4 on: June 02, 2014, 05:53:46 PM »
Hi Mark,
Cheers.
Thanks Lobo, I will retain the original engine mount earth as you have suggested.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
