CB350/400
Points cable sheathing...
Topic: Points cable sheathing... (Read 7808 times)
ted_paper
SOHC Member
June 14, 2014, 08:23:27 AM »
Not sure exactly what it's called, but the braided cable cover to the points has worn away at the pinch points. Does anyone know where I can get a replacement for this?
Trigger
Re: Points cable sheathing...
June 14, 2014, 10:04:03 AM »
It is called 6mm heat resistant sleeving, here is a link. >>
http://www.ebay.co.uk/itm/6MM-BLACK-HEAT-RESISTANT-SLEEVING-CABLE-WIRE-HIGH-TEMPERATURE-PER-METER-/221234967418?pt=UK_BOI_Materials_Supplies_Electrical_ET&hash=item3382a1b37a
ted_paper
SOHC Member
June 14, 2014, 10:05:28 AM »
Brill...thanks!
AshimotoK0
Mad Scientist.... more power Igor ! Ù©(̾à¹Ì®Ì®ÌƒÌ¾à¹ÌƒÌ¾)Û¶
June 14, 2014, 10:10:38 AM »
I think I have some of the white stuff. Will check!! I also have the same for the 750 alternator sub-harness. glass filled silicone coated.
Cheers ... Ash
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.†Grace Slick, Woodstock '69 .. In the year of the Sandcast.
ted_paper
SOHC Member
June 14, 2014, 10:57:40 AM »
Thanks Ash.
I'll wait to hear from you before I order from Ebay
AshimotoK0
June 16, 2014, 07:29:39 AM »
Was away over wekkend .. I will check tonight.
Cheers ... AshD
ted_paper
SOHC Member
June 16, 2014, 08:21:14 AM »
I'll be away myself until Thursday, so there's no rush.
AshimotoK0
June 18, 2014, 08:33:05 AM »
Hi,
I think the two sizes I have lots of are smaller and larger, than the points covering, bought for the Alternator sub harness on my 750K0 (see pic) but I need to get some points stuff anyway for my 750 and 250 so if you can wait a week I will get some and let you have a piece in the correct white colour.
Cheers ... AshD
Last Edit: June 18, 2014, 09:50:02 AM by AshimotoK0
ted_paper
SOHC Member
June 19, 2014, 05:47:07 PM »
Hi Ash,
That would be great - much appreciated.
Thanks.
AshimotoK0
June 23, 2014, 09:58:46 PM »
I have found four different size reels of that sleeving in my garage. Let me have your address and I will send you some Ted. What length do you need?
Cheers ... AshD
ted_paper
SOHC Member
Reply #10 on:
June 24, 2014, 07:34:45 PM »
Thanks Ash,
PM sent.
AshimotoK0
Reply #11 on:
June 24, 2014, 10:40:59 PM »
No pm yet Ted email is ashleyatsmartsolutionsdotkaroodotcodotuk
Cheers ... Ash
AshimotoK0
Reply #12 on:
June 26, 2014, 02:43:19 PM »
Posted today RM 1st class. Please let you know when you receive.
Cheers ... AshD
ted_paper
SOHC Member
Reply #13 on:
June 26, 2014, 08:00:43 PM »
Will do!
ted_paper
SOHC Member
Reply #14 on:
June 27, 2014, 05:36:28 PM »
Hi Ash,
Cables arrived safely today.
Thank you
CB350/400
