CB750
Speedo gear box
Topic: Speedo gear box (Read 4728 times)
billy192
SOHC Expert
Speedo gear box
June 20, 2014, 02:18:01 PM »
I have as you know a CB750 K6. the speedo is recording 70mph when i am doing 50mph. as i have spare gear boxes from a 250 and 500 could i have put the wrong one on or are they all the same as the front wheel is the same DIA?
Billy
o
Billy
Trigger
Re: Speedo gear box
June 20, 2014, 02:29:16 PM »
Billy, i had the same problem with a CB550 clock. Stripped it - rebuilt it with a load of new parts and still had the same problem. In the end i sent it to Clockndials and he fixed it. May be worth giving him a ring.
Bitsa (Ralph Wright - RIP)
Re: Speedo gear box
June 20, 2014, 03:09:33 PM »
Trig,
Its taken me ages to get a decent set of clocks and even now I am not 100 percent happy with those.I have had two sets done by pros and there still shit in my opinion.
Got there number mate?Forgot to add the worst was REPLICAS from DS sent them back twice and the third set still crap.
Bitsa
Last Edit: June 20, 2014, 03:12:14 PM by Bitsa
Green1
Re: Speedo gear box
June 20, 2014, 07:12:28 PM »
At least you have the option of replica clocks my k1 speedo has been pants from day one and made far worse after it's bump on the nose.The trip and odo are now jammed and it reads about 20mph+ to fast.A second hand k1 speedo sells for around £160+
I have just tracked down a low mileage Laverda Jota speedo which is the same internally as the k1 so hopefully after a rebuild it will be as good as new.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Re: Speedo gear box
June 20, 2014, 09:51:22 PM »
500 and 750 gearbox are the same part number, not sure about 250
Re: Speedo gear box
June 21, 2014, 09:36:06 AM »
Green 1,
What is good about having options when they are crap ones?
Like I have said b4 I have no problems with other firms making duplicates but for christ sake make sure they work good even if they cost double.
Bitsa
billy192
SOHC Expert
Re: Speedo gear box
June 21, 2014, 10:02:10 PM »
Thanks Bryan,
I thought i would never get the answer.
I will try all three as now I am not sure which is which LOL
Bitsa your correct do it well or don't bother
Billy
Billy
Re: Speedo gear box
June 22, 2014, 10:48:50 AM »
Billy
Bryan could be right Cant find part number for your 250G5 but for the 360G5 I assume that they are the same the middle number is 317 where as 750 is 300
Hope that helps you out
Bitsa
billy192
SOHC Expert
Re: Speedo gear box
July 02, 2014, 12:53:57 PM »
is the part number stamped anywhere on the part?
Billy
Billy
Re: Speedo gear box
July 02, 2014, 01:56:05 PM »
Billy
Just looked on mine sorry mate could not see anything from the outside
Bitsa
CB750
Speedo gear box
