Author Topic: Front Sprocket question  (Read 5133 times)
Offline hunterso
« on: June 25, 2014, 11:59:56 PM »
Not had a lot of time to spend on the bike recently.
Fixing the front sprocket on tonight - new sprocket, new retainer clip, new bolts.
I have looked in the manual but cant find any info on how tight the bolts need to be.
Do they need to be torqued up to a specific figure or can they just be nipped up with a smear of thread lock?
Also it seems there are no washers required according to diagrams i have seen.
Was thinking of putting some serrated washers under the bolts?
Re: Front Sprocket question
« Reply #1 on: June 26, 2014, 06:46:46 AM »
Don't need washers, never used threadlock just done em up tight
Offline bomber
« Reply #2 on: June 26, 2014, 10:38:21 AM »
I was wondering about it also, my conclusion is that since the screws go into the steel, there is no need to worry with torque.
Then again thread lock sounds like a good idea, any thoughts against it?
One step forward, two steps backward...
Honda CB550F 1976
Offline hunterso
« Reply #3 on: June 26, 2014, 09:44:55 PM »
Thanks Bryan
Like you bomber - i think a little smear of thread lock wont do any harm
« Reply #4 on: June 26, 2014, 11:35:42 PM »
Knowing how much of a bstrd they can be to undo when all that has happened is that they bin there for years i disagree on thethreadlock
« Reply #5 on: June 26, 2014, 11:48:16 PM »
I always do them to 11 Ibs-ft and have never had one fall out.
Offline hunterso
« Reply #6 on: June 27, 2014, 12:05:43 PM »
Good point bryan
Trigger - just what i needed
