Author Topic: float hight  (Read 3626 times)
Offline billy192
    • Shermonkel
float hight
« on: June 26, 2014, 08:33:09 AM »
for my K6 750 the float hight is 26mm some say from the gasket face some say the lip.
http://www.salocal.com/sohc/tech/carb/asmpg_mgs/flthgt.htm  this Guy says he has always done from the lip with no problem.
as I am about to remove my carbs and chek what is the consencus on here please?
Billy
Billy
Re: float hight
« Reply #1 on: June 26, 2014, 09:09:22 AM »
Billy,
I have heard and read lots about this and like me using a Honda gauge as you can see from your link photos its impossible to get the tool LEG in between the ridge of the carb and float making the measurement from gasket surface real hard to do if again impossible using the Honda gauge.Conclusion if its good enough for Honda then that's the way.I have done mine that way and she runs fine.
Bitsa
Offline billy192
    • Shermonkel
Re: float hight
« Reply #2 on: June 26, 2014, 09:14:11 AM »
thanks Bitsa,
i will set 26mm from the lip. it has to be better than what i have.
Billy
Billy
Re: float hight
« Reply #3 on: June 26, 2014, 09:47:19 AM »
Billy
Just to refresh my head just checked you measure from the cut out on the carb body see pics and these are 2 different sets.
Bitsa
Offline billy192
    • Shermonkel
Re: float hight
« Reply #4 on: June 26, 2014, 10:01:35 PM »
just finished the job and yes i measured from the cut out. fingers crossed i will give it a quick ride weather permitting and see.
Billy
Billy
