Author Topic: spare key  (Read 5006 times)
Offline El__burro
spare key
« on: June 30, 2014, 05:41:14 PM »
Hello,
Are the ignition key and the steering lock the same?
 (assuming that they are original)
Where can i buy or get a copy of one.
El__burro
Re: spare key
« Reply #1 on: June 30, 2014, 07:19:29 PM »
I use this man in the link. He will cut a key for you from the key number. He is on his holidays until 5th July.>>>  http://stores.ebay.co.uk/MB-Lock-Tec?_trksid=p2047675.l2563
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: spare key
« Reply #2 on: June 30, 2014, 11:33:13 PM »
Yes, on an original bike the keys are the same... includng the helmet lock. The locking petrol filler will take 'any' key. Copies are fairly easy to come by...
Just beware that often copy keys will be a different shape to OEM Honda: in my case the copies wouldn't operate the steering lock as their shoulders stopped them pushing up the barrel to engage the lock. You'll notice I modified the top key (expand picture) modified with a hack saw & solder....
Cheers,
Simon
« Last Edit: June 30, 2014, 11:35:53 PM by Lobo »
Offline El__burro
Re: spare key
« Reply #3 on: July 01, 2014, 08:04:05 AM »
Thank you both,
Ill wait until the ebay seller returns from holidays.
Regards
El__burro
Offline Waggles
Re: spare key
« Reply #4 on: July 03, 2014, 07:48:21 AM »
Bear in mind this all changed with the F1 which has one key for ignition/seat/and fuel cap and an entirely different one for the headstock
Offline El__burro
Re: spare key
« Reply #5 on: October 06, 2014, 08:22:41 AM »
Does the ignition key comes off when you turn the ignition on.
This one does,  is it normal?
Re: spare key
« Reply #6 on: October 06, 2014, 08:51:40 AM »
The ignition key should not come out once the ignition is on (only in the off and park) If the key comes out in the on position this means the ignition barrel is worn.
Offline El__burro
Re: spare key
« Reply #7 on: October 22, 2014, 03:49:37 PM »
So..
I have 3 possible position for the key,  1, 2 and 3.
The key stays IN only at position 2.
position 1 and 3 key comes off.
Is this normal?
Re: spare key
« Reply #8 on: October 22, 2014, 03:59:15 PM »
So..
if the ignition is on at Pos 2 ,and all off at pos 1,and park lights on pos 3, that is normal
Is this normal?
Offline El__burro
Re: spare key
« Reply #9 on: October 22, 2014, 04:19:31 PM »
Thanks, honestly i cannot tell as i have no wiring attached to it.
Re: spare key
« Reply #10 on: October 22, 2014, 09:51:51 PM »
So..
Is this normal?
Position 1) is Off and the key should come out.
Position 2) is On and the key should not come out.
Position 3) is park which should leave your tail light and side light on. Key should come out.
« Last Edit: October 23, 2014, 09:04:25 AM by SteveD CB500F »
