Author Topic: Charging  (Read 10176 times)
Offline hondatri
Charging
« on: July 01, 2014, 04:25:55 PM »
Me again guys have not got near clutch yet now I have found another problem. I went on a charity run a few months ago we were advised to ride with headlights on after 28 miles my Battery was dead I Charged it up and it seemed ok until I put headlight on. I took battery out yesterday and found that water level was near bottom I topped it up with distilled water and charged it up. I left it disconnected overnight and this am voltage was 12.3v I went for a run of 15 miles and when I got back Batt was 11.94. I connected an ammeter in series with Pos lead and got following Readings. Idle 0A  2K=2A  3K=4A and 4K= 6A. When Headlight put on Charge was 0A at all revs. Reconnected Battery and got following Voltages. Idle=11.64, 2K=12.08, 3K=12.50 4K=12.80. With head light on the voltage never went over 11.75V. I have a Haynes Manual and am going to check Alternator out put I had a look at voltage reg. and cleaned contacts it is the non adjustable one. Has anyone got any ideas as to what I should look out for.Should I get a new Battery first.
Re: Charging
« Reply #1 on: July 01, 2014, 08:54:31 PM »
Corroded connectors or grounds are the favourate there , also voltage drop on the black lead at the regulator
Offline hondatri
Re: Charging
« Reply #2 on: July 02, 2014, 01:39:02 PM »
Thanks Bryanj I had Reg off to see if it was adjustable and I cleaned th three connectors and put some WD40 on them. I will chase up circuit and do the same with all connectors. Do you know where the Main Earth point is and do you think I should replace Battery due to going low on water and refilling.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Charging
« Reply #3 on: July 03, 2014, 06:56:24 AM »
...found these pages from a '400 manual if it helps...
Slightly confused, as the battery sounds like its being overcharged ('water' disappearing)... and yet from your description its definitely being undercharged (voltage should be around the 15v area during running)
Given that you're not achieving 15v, and assuming all connections / loom good... then I'd suspect the Voltage regulator. Hopefully the attached pages / your Haynes will confirm or otherwise.
Has the bike been 'upgraded' with respect to lights? I think the original head was a 50/35W lamp.
If there is any doubt as to the age / condition of your battery then, yes, perhaps you should change it.
Offline hondatri
Re: Charging
« Reply #4 on: July 04, 2014, 04:30:23 PM »
I appreciate that info. Does anyone know what the AC voltage from alternator should be. Thanks Again. I am going for a new Battery first.
Re: Charging
« Reply #5 on: July 04, 2014, 05:09:16 PM »
Hondatri, You say that the battery was nearly empty. This indicates a overcharging problem and then you filled it with distilled water. Distilled water should only be used as a top-up. If you filled it up again with distilled water it should not fully charge. When a battery is that drained you should fill it with battery acid.
Re: Charging
« Reply #6 on: July 04, 2014, 06:18:17 PM »
NOOOOOOO no matter how empty(unless spilled out) you should onl use distilled water as water vapour is all that has gone leaving super concentrated acid, having said that a tired battery will gass excesssively and empty so a new one is probably a good idea. From experience pay the extra and spring for a Yuasa not a cheepie ALSO the need to be trickle charged for a day before fitting, not doing so shortens the life remarkably
Re: Charging
« Reply #7 on: July 04, 2014, 06:31:36 PM »
Bryan, i had a over charging problem on a GSX-R and when i filled it up with distilled water it would not take a charge. Emptied and filled it up with new acid and it took a full charge.
Re: Charging
« Reply #8 on: July 04, 2014, 06:42:32 PM »
I rest my case ready rubs again
Bitsa
Re: Charging
« Reply #9 on: July 04, 2014, 06:43:39 PM »
Bitsa, Go back down the pub ;D
Re: Charging
« Reply #10 on: July 04, 2014, 10:13:35 PM »
Trigger that goes against all practice and theories, but then you did say EMPTIED and refiled which is way better than just top up
Offline hondatri
Re: Charging
« Reply #11 on: July 05, 2014, 07:37:14 PM »
Hi Guys Like the Banter.Seriously I am going to go through the wiring and replace the Battery and Fingers crossed All will be ok. I wont get near it until next week so I will keep posted. Thanks to all.
Offline hondatri
Re: Charging
« Reply #12 on: July 20, 2014, 07:39:36 PM »
Did not get near bike due to other problems but I have a more serious problem Put ammeter in line with Pos lead to battery again  and when I turned on the Ign the ammeter wett to full discharge (Fully left) came back to show a charge when engine started  then lights on went a little to left. I will have to go over all systems or if any other suggestions I would appreciate.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Charging
« Reply #13 on: July 21, 2014, 01:04:03 AM »
Hi again Hondatri.
You really need a multi meter with a 10A scale for this...  most meters we guys tend to use don't go up this high.
And before you waste any time on the below, heed Bryan's basic advice of ensuring ALL electrical connections clean & sound... this to include all the various EARTHs.
And if your battery's health is in doubt... replace it.
We need a little more info here..specifically the Ampere scale you selected in the above post. Ie, if the needle went full left (discharge) at a 1A scale... well fine, but at a 10A scale... er, problems.
With the ignition coils de-energised, ie the kill switch OFF, the only load @ ignition ON ought to be the generator field at around 1.6A. Significantly more than this (assuming all lights off etc) should be cause for investigation.
Suggest: Connect your meter in series with the battery, and via the kick start, start the engine. (If you use the elect start you'll pass 120A through your meter & frazzle it ie DON'T use the elect start)
Give the bike a few mins to electrically settle down... (lights OFF)
Then check the ammeter...  iaw the 'charging characteristics' table in the first document I posted above, ie lights On & Off @ the various RPM ranges. Make a note... and report back to the forum, somebody may recognise the symptom and give you the benefit of their experience.
If a significant discharge is apparent, try pulling / replacing the bikes fuses one by one. and if a significant (+ve) change suddenly  takes place... well you've found the problem circuit.
If no luck with any of the above suggest you stop bench test each component of the bike's charging circuit ie test each component in isolation / iaw the manual,
ie generator windings, rectifier check, regulator check. The specs can be found in the bike's manual... if needed I'll post the pages.
Simon
« Last Edit: July 21, 2014, 06:25:56 AM by Lobo »
Offline hondatri
Re: Charging
« Reply #14 on: July 21, 2014, 12:17:05 PM »
Thanks for Post. The ammeter I am using is a Millar Motorcycle Ammeter Charge/Discharge 8 amps. It is deflecting to full discharge.I will get to bike tomorrow and hope I will find the Problem.
