Author Topic: Liquid sealant and filter question  (Read 4859 times)
Offline Greg65
« on: July 03, 2014, 07:56:02 PM »
Advice from the wise please.
First up I was wondering what "liquid sealant" I should use when replacing the socket bolt at the base of the front forks?
Secondly, I am missing the filter from the base of the air box that goes between the two panches. DSS does not have any so was wondering what material to use and then trim to fit. Suggestions please.
Cheers Greg
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
Offline Clem2112
  • Midlife
Re: Liquid sealant and filter question
« Reply #1 on: July 03, 2014, 09:12:05 PM »
Wise?...... Oh well here goes...
I didn't use sealant. Most likely  I used loctite on the threads to prevent that cap screw from loosening out of the damper rod.
I think the washer under the cap head (possibly Aluminium or copper ?) should seal it up ok.
Never leaked yet !
Honda put a small oblong piece of foam between the mesh pieces.
This was supposed to filter out oil vapour from the blow-by gases exiting the rocker cover.
You should wash this with petrol (or suitable cleaner !) ... according to the service schedule.
I used a folded piece of cooker hood filter material in this space.
« Reply #2 on: July 03, 2014, 09:36:56 PM »
Don't use sealant unless you want to pass on a shite job to the next owner (getting the bolt out)
Offline Greg65
« Reply #3 on: July 04, 2014, 06:21:29 AM »
Cooker hood material, great, have some of that. Thanks Clem.
Sounds like good advice Bryanj and will apply.
Cheers guys :D
Honda CB400 1976
Suzuki GS1000 1978
