Author Topic: Restoration of Sandcast Frame 5369/ Engine E5479  (Read 59558 times)
Offline UK Pete
« on: July 19, 2014, 07:48:10 PM »
Here goes for another restoration thread, i have another thread going for diecast 9574, which i will carry on with but at an even slower pace than it has been going at, for now the Sandcast takes priority and it will also take some of the diecast parts i had stashed
Here is the bike as i bought it, the head and barrels are off a later bike, there are no brackets or fixings whatsoever, just an incomplete bottom end of engine, frame, swingarm, wrinkle tank, oil tank, wheels, and a couple of beat up guards
As you my well see there is a hell of a lot missing but hey beggars cant be choosers,
The parts i most need are carbs, head and barrels, 9 hole clutch cover, double cut front guard, complete front brake set up
First of all i was itching to get the engine apart, fully expecting to find all sorts of nasty surprises, firstly i removed the studs, never an easy job especially on a 45 year beat up old engine
Then the moment of truth, open up the cases
Well all i can say is thank you god, the inside is in perfect unworn condition, the only mess in there was a small mouse nest, all the bearings were oiled and smooth running, the crank and its shells look as good as a bike thats only done 100 miles 0% wear, all gear cogs intact, and best of all no nasty chain break damage to the casings,
I have to say i have never been so excited about a bike restoration like i am about this one, guys its official i have SANCAST FEVER , and i have got it real bad,
bye for now
pete
Offline Green1
Re: Restoration of Sandcast Frame 5369/ Engine E5479
« Reply #1 on: July 19, 2014, 08:07:43 PM »
You lucky lucky beggar
Looks like you've got your work cut out.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #2 on: July 19, 2014, 08:18:18 PM »
Pete, is this the one from Freddy the Frog?
Offline UK Pete
« Reply #3 on: July 19, 2014, 08:43:51 PM »
Mick certainly have got my work cut out, but thats the fun tracking down parts from (mostly USA), and doing as much work on the bike as i can myself, this is certainly a restoration for the brave, it will be a fine motorcycle when its done
 Graham, yes you got it right it is the one from fat freddy (will dawkins ) from classic bike imorts
« Last Edit: July 20, 2014, 07:26:52 AM by UK Pete »
Offline mick
« Reply #4 on: July 19, 2014, 11:03:05 PM »
Nice one Pete  8), I'm looking forward to this thread, you've got your work cut out on this one but like you say half the fun is finding all the pieces of the puzzle
make sure you post plenty of photos as you find / do stuff  ;) cheers Mick.
Offline UK Pete
« Reply #5 on: July 20, 2014, 07:33:08 AM »
Thanks Mick, there will be hundreds of pictures, again half the fun for me is getting as much up here in pictures for you guys to see
it helps to keep the interest alive, plus i can look back and enjoy, i still have my 69 diecast on the go at the same time , i wont be giving up on that, things will just go on ahead at whatever pace suits me , no point in rushing
pete
« Reply #6 on: July 20, 2014, 08:06:12 AM »
Did 'Freddie' give you any indication of how he managed to find 4 sandcast restos at around the same time Pete? At least he also sells off engine parts from USA imports sometimes. Have you noticed D&K will only really sell the complete motors (well for Cb350 motors, not sure on others) with no indication on the true state of them internally other than the standard ' weather seized' and some decent external photos. I was talking to their guy Pete on the 'phone a while back and he say he can sell that type of engine for (CB350 twins) all day long for around 350GBP so why sell engines for parts. Looks to me like some will be a real bargain, others will be full of rust inside. But I can't a afford a 350 quid 'punt'. It would be a five minute job to remove the cam cover and the state of the cam/rockers would be  a real good indication of the true engine state.
Cheers ... AshD
« Last Edit: July 20, 2014, 08:28:45 AM by AshimotoK0 »
Offline UK Pete
« Reply #7 on: July 20, 2014, 09:29:00 AM »
Yes will told me the story, not sure if its ok to spread on a forum i can tell you off air
DK is a lucky dipp i have had some real clean low milage parts from them, on the other hand i have had some total heaps of shit at the same price as the good stuff, on the whole i think they are ok, it is a lucky dip with engines, but other parts have good up close pictures so its a bit easier to determine
pete
Offline UK Pete
« Reply #8 on: July 21, 2014, 04:29:24 PM »
Ok guys a bit more progress, i washed the crankcases in my parts washer, then pressure washed them, dried them in the oven , blasted them clean getting rid of all that thick black paint, then pressure washed them again, oven dried them blew them through with an air line, washed them in thinners and masked them ready for spraying
« Reply #9 on: July 21, 2014, 05:31:05 PM »
Pete, I seem to remember the inside of the cases had a yellow paint? to counter pourosity
Offline RGP750
« Reply #10 on: July 21, 2014, 06:28:00 PM »
As a patternmaker and supplier of castings it's nice to see a closeup of the cases.
there are internal paints available to counteract possible porosity.
www.dialpatterns.co.uk
Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline UK Pete
« Reply #11 on: July 21, 2014, 07:17:54 PM »
There does seem to be an internal coating to the insides, i only cleaned off the outsides by blasting, the insides remain as was
pete
Offline mickwinf
« Reply #12 on: July 21, 2014, 07:37:10 PM »
those cases look a bit rough, get the dremell out and polish them smooth  :D
Offline Green1
« Reply #13 on: July 21, 2014, 07:46:41 PM »
Going well Pete
I can't even find the time to wash mine.
I only mended my speedo today as I was stopped by the Oinks the other day.
Mick
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline UK Pete
« Reply #14 on: July 21, 2014, 07:49:59 PM »
