Author Topic: swingarm bushing dimensions  (Read 7627 times)
Offline Erny
  • CB750K7 CB550K1
Re: swingarm bushing dimensions
« Reply #15 on: March 24, 2019, 09:59:39 PM »
I took pics and made video too. These are bushings I got new from PO
CB750K7 US model (1977)
CB550K1 US model (1975)
« Reply #16 on: March 24, 2019, 10:04:51 PM »
Then they are the correct bushes for your bike and are the same as myself and Frank would supply, identical.
Offline Erny
  • CB750K7 CB550K1
« Reply #17 on: March 24, 2019, 10:17:40 PM »
So what's wrong? They cannot go inside swingarm by thumb...
« Reply #18 on: March 24, 2019, 10:20:07 PM »
Hang on one moment and I will give you the dimensions of the bush I sell so you can compare.
Offline Erny
  • CB750K7 CB550K1
« Reply #19 on: March 24, 2019, 10:25:07 PM »
If I compare new bronze and old stock I see difference (absolute value might not be perfect due to caliper)
« Reply #20 on: March 24, 2019, 10:25:13 PM »
The measurements are as follows:-
OD 26.50
ID 21.40
Total length 44.00
Depth of top lip 2.00
OD of lip collar 31.90
Length excluding collar 42.00 (length sitting inside swing arm)
« Reply #21 on: March 24, 2019, 10:30:02 PM »
Your original bushes, the ones supplied by the PO and the ones I sell measure so close together to make no difference. I would measure the ID of your swing arm and compare with another CB500/4 swing arm. I see you have had your swing arm powder coated. Did you block off the ends before or leave open and then clean powder coat out?
« Reply #22 on: March 24, 2019, 10:33:21 PM »
Are your old bushes loose in the swing arm now?
Offline Erny
  • CB750K7 CB550K1
« Reply #23 on: March 24, 2019, 10:43:01 PM »
No it is not powder coated. It is only sprayed with black spray. Holes were covered when spraying. If I take mechanical caliper, ID of swing arm is 26.50 OD of bushings 26.4...
Offline Erny
  • CB750K7 CB550K1
« Reply #24 on: March 24, 2019, 10:43:31 PM »
No they are tight. I'm certain they are original
« Reply #25 on: March 24, 2019, 10:48:01 PM »
Going by your measurements 0.02mm difference should not really make them that loose in the swing arm.
« Last Edit: March 24, 2019, 10:52:26 PM by Nurse Julie »
Offline Erny
  • CB750K7 CB550K1
« Reply #26 on: March 24, 2019, 10:52:49 PM »
OD 26.50
ID 21.40
Total length 44.00
Measured (using the same mechanical caliper that I can rely on)
OD 26.40
ID 21.70 (yes, they have play over the brand new oem collar 52141-300-000)
Total length 44.0
Depth of top lip 1.80
OD of lip collar 32.00
Length exl collar 42
So seems there are discrepancies - too small OD too small ID. Maybe also lip not wide enough?
Offline Erny
  • CB750K7 CB550K1
« Reply #27 on: March 24, 2019, 11:01:04 PM »
How it looks with when assembled - play. Is that normal?
https://youtu.be/R27AaQF6wPw
« Reply #28 on: March 24, 2019, 11:03:29 PM »
If your measurements are correct, but I can also see discrepancies in your measuring, I would agree they are to small. I am wondering why they were not fitted by PO ? I wonder if they have been turned down for some reason.
« Reply #29 on: March 24, 2019, 11:09:16 PM »
You can't assess it like that. I have just measured 5 new bushes with the micrometer and they all measure an average if this [ Guests cannot view attachments ]
