Author Topic: replica shock absorbers  (Read 13619 times)
Offline wolfheze
« on: August 07, 2014, 08:07:26 PM »
Hi all. Has anyone tried the replica shock absorbers from silvers? I have a K2 with aftermarket shock absorbers which are too long. Although they seem fairly well sprung and damped the increase in rear ride height is causing some interesting high speed stability issues ! Would like to sort this out but not at the expense of a wallowy rear end.
               Many thanks.
Re: replica shock absorbers
« Reply #1 on: August 07, 2014, 08:18:03 PM »
The ones DSS sell are bloody expensive for what they are. Try a guy on ebay, goes by the name of 101 Turbogas. Fitted a few of his shocks with no complaints.
Found a link>>>   http://www.ebay.co.uk/itm/321484928581?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
« Last Edit: August 07, 2014, 08:25:37 PM by trigger6969 »
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
« Reply #2 on: August 07, 2014, 08:26:55 PM »
hey Wolf ... do you get front end tank slapper tendencies and what lenght are the rear shocks. Got some tank slapping tendencies with +48mm shocks masel
500K1 basket case for later
Offline wolfheze
« Reply #3 on: August 07, 2014, 08:37:03 PM »
Ok thanks for the quick response!
I will check out the ebay guy. Yes above 80 mph it starts to feel distinctly unstable. although dosent feel as though its going to develop into a full blown slapper it is a little disconcerting and quite tiring to ride. shock absorber length is 13.5 inches. I think standard ones are 13 ?.
« Reply #4 on: August 07, 2014, 08:45:55 PM »
I bought a set from silvers a while back 3 years or more,as for handling all I can say they are fine up to 70mph never gone any faster than that I am in no rush here.
Bitsa
Offline Ewan 500 K1
« Reply #5 on: August 07, 2014, 08:56:01 PM »
.. standard rears are 315mm on the 500, Hagon do one that suits. Probs do one for 750 too
« Last Edit: August 07, 2014, 09:35:26 PM by Ewan 500 K1 »
« Reply #6 on: August 07, 2014, 09:13:48 PM »
Before you condemn the existing shocks, do a thorough test on the swinging arm bushes and rear wheel bearings if you haven't already done so. Knackered swingarm bushes can also cause the symptoms you describe, and I don't think half an inch longer shocks would make that much difference.
Offline wolfheze
« Reply #7 on: August 07, 2014, 09:41:37 PM »
Already checked bushes and bearings, seem to be ok. Is better with a passenger [lower ride height] so am thinking it is a geometry problem. sure i read somewhere 70s cb already had a short trail by the standards of the time.I am used to more modern bikes when a few  mm of ride height will make quite a big difference to the steering.
« Last Edit: August 07, 2014, 09:51:12 PM by wolfheze »
Offline Ewan 500 K1
« Reply #8 on: August 07, 2014, 09:54:28 PM »
... remember reading that trail varies acroos the 750 models. If I remember right its the later ones that have the shorter trail ... damned if I can remember where I read what the differences between models though ... but i'd agree that an extra half inch at the rear end doesn't seem that much . Could you borrow a standard set off someone first to see if it makes a diff ?
Offline wolfheze
« Reply #9 on: August 08, 2014, 04:49:03 AM »
Could be worth trying some standard ones first, i know where i can borrow a pair.
« Reply #10 on: August 08, 2014, 04:07:48 PM »
Where are you?
Put your location in your profile.
I've got a set of 550F shocks in the barn.
Steve
« Reply #11 on: August 08, 2014, 05:32:14 PM »
My memory could be wrong but i think when it was Girling making the shocks all the fours were listed as the same shock with different springs
Offline wolfheze
« Reply #12 on: August 09, 2014, 05:07:09 AM »
Have managed to aquire a pair of dampers that dont look to have seen much use.
They have some very light pitting on the shrouds, is it possible to take them off for recroming?
« Reply #13 on: August 09, 2014, 10:19:01 AM »
Yes but be carefull
Offline wolfheze
« Reply #14 on: August 09, 2014, 12:23:55 PM »
How do they come off? Dont worry i will be careful, mate had a jaguar spring smash his jaw when a spring compressor failed.
