Author Topic: Carburettor Rebuild Time... Help!  (Read 15650 times)
Offline Drew400
  • 400/4 I restored
Re: Carburettor Rebuild Time... Help!
« Reply #15 on: August 11, 2014, 10:03:53 PM »
OK will do, ta, D.
Offline Drew400
  • 400/4 I restored
« Reply #16 on: August 17, 2014, 09:31:54 AM »
Hello all,
A quick update: vaseline worked, other tips worked, etc. and a thing of beauty has appeared (albeit, we don't know yet if it works... and I have three more to go!):
Thank you again,
D.
« Reply #17 on: August 17, 2014, 09:37:35 AM »
Well done drew. Nice work...
Offline Drew400
  • 400/4 I restored
« Reply #18 on: August 17, 2014, 12:46:33 PM »
Thanks Jamesh, although I can't claim credit for all of the cleanliness you can see, only some of it!
Cheers, D.
Offline Drew400
  • 400/4 I restored
« Reply #19 on: August 17, 2014, 08:32:53 PM »
Hello,
Has anyone got one of these? It's the spring thing from carburettor float bowl.
It fell in half (honest... no bending or anything) as I was holding it! Uri Geller, eat your heart out.
Can't see one on DS or 400fourbits websites.
Thank you in anticipation.
D.
« Reply #20 on: August 17, 2014, 08:44:51 PM »
Opp,s You will have to find the Dutch man for one of those.
Link>>>  http://www.ebay.co.uk/itm/Honda-carburetor-leaf-spring-CB500-CB550-C350-CB400-set-of-4-16061-323-004-/111428765291?pt=UK_Motorcycle_Parts_13&hash=item19f1ac066b
Or he does them at £7.50 each. If they are old they will brake.
« Last Edit: August 17, 2014, 08:53:22 PM by trigger6969 »
Offline Drew400
  • 400/4 I restored
« Reply #21 on: August 17, 2014, 10:08:31 PM »
Ah , thank you, Trigger for your expertise and reply. I guess if one has broken, the others won't be very reliable. Maybe a set of 4 is wise.
Cheers,
D
« Reply #22 on: August 17, 2014, 10:19:56 PM »
If you go on his site Drew and look to pay in $ it is cheaper.
Offline Drew400
  • 400/4 I restored
« Reply #23 on: August 17, 2014, 10:22:24 PM »
Too late, bought on e-Bay, but thanks for the thought. Cheers, D.
« Reply #24 on: August 17, 2014, 10:30:36 PM »
You are too quick for me Drew.
This Dutch guy is a guru when it comes to carbs but, he always has two prices and the $ is always the cheaper option.
Offline Drew400
  • 400/4 I restored
« Reply #25 on: August 25, 2014, 10:51:46 AM »
My four things of beauty are now all fastened together and I'm doing the final adjustments before putting to one side to await the engine rebuild. However, I have a question for you experts:
Should the throttle slide be all the way down at the bottom of of its tunnel? I seem to have a small gap at the bottom of c.3mm at its highest point (see photo). I can adjust them upwards (i.e. increase the gap) but nothing doing to close the gap entirely, hence this question.
Hopefully a wet bank holiday will find many of you, like me, in front of a computer and/or engine parts as I write!
Cheers and thank you,
D.
Online SteveD CB500K0
« Reply #26 on: August 25, 2014, 11:21:37 AM »
There should be a gap (otherwise the bike would never tick over.
I always "knew" it was 1/8th" and used a drill bit to set it.
Not sure where I got that from or how authentic it is - but always worked for me.
Steve
Offline Drew400
  • 400/4 I restored
« Reply #27 on: August 25, 2014, 11:33:41 AM »
Thank you Steve, you've put my mind at rest. I didn't remove the sliders from their arms when removing them from the car bodies and so I doubted I could have messed up their settings and was thus hoping for the the answer you have just sent!
Great, I can now crack on with more rebuild stuff!
Cheers,
D.
Offline Clem2112
  • Midlife
« Reply #28 on: August 25, 2014, 01:11:22 PM »
Re the gap in the carb venturi...
When you eventually come to balance the carbs, about the last task after a re-build, this gap gets adjusted to equalise the vacuum reading for each cylinder.....  All that fun to come !
Offline Drew400
  • 400/4 I restored
« Reply #29 on: August 25, 2014, 01:42:19 PM »
Can't wait, I think!
Thanks Clem.
D.
