Author Topic: Taper head race bearings.  (Read 10384 times)
Re: Taper head race bearings.
« Reply #15 on: August 16, 2014, 07:46:56 PM »
TRIG
knew it and never meet you mad git
Bitsa
« Reply #16 on: August 16, 2014, 08:04:25 PM »
I will keep quite on my top speed then ;) It was a bit over 210
« Reply #17 on: September 14, 2014, 03:50:15 PM »
Just got some seals for the taper bearings. They are not what I expected really and now I am not too sure where they go. The seal is like a U shape that looks like the spacer washer goes inside it. It that correct? If it is correct, that would mean the front end of the bike is supported on the rubber seal, or am i missing something. Cheers.
« Reply #18 on: September 14, 2014, 04:36:31 PM »
This seal is only a dust seal. You put the big washer on the stem first than the dust seal. The front end is supported by the bearings not the dust seal.
« Reply #19 on: September 14, 2014, 04:55:28 PM »
Thanks for the reply Trigger. Will give that a go. Was just concerned that this rubber seal will be trapped between the spacer and the bearing, making setting the bearing play a bit hit and miss. What I was expecting to receive was the older type seal with the steel inner like the ones supplied in the Allballs kit. Never mind will give it a go. Cheers.
« Reply #20 on: September 14, 2014, 05:20:51 PM »
I have seen them the other way round as well, with the seal on first then the washer. As you tighten it up the seal wraps round the washer but, the seal needs to be a bigger OD dia than the washer for that to happen.
Offline Ian DB
« Reply #21 on: September 14, 2014, 05:51:37 PM »
This might help, Installation instructions from Allballsracing.com
http://www.allballsracing.com/media/installation/22-1011_washers.pdf
« Reply #22 on: September 14, 2014, 06:23:10 PM »
Great
Nice name though
Bitsa
« Reply #23 on: September 15, 2014, 06:19:06 PM »
Yep sure enough, put the front together and the whole weight of the bikes front is on the rubber dust seal as its trapped between the spacer washer and the bearing. That surely cant be right. Can it? Anybody know where I can get seals like the ones in the Allballs kit. Thanks.
Offline Ian DB
« Reply #24 on: September 15, 2014, 09:03:22 PM »
« Reply #25 on: September 16, 2014, 11:03:52 AM »
Okay sorted it. If anybody requires the correct seal the DSS part number is FDCBE-371-010P (Honda part number 53214-371-010). They are £2.95p plus the usual unbelievable postage charge. These are the ones with the steel centre core that the bearing sits on, with the rubber outer seal bonded to it. Cheers all and thanks for all your help and suggestions.
