Author Topic: changing valves to different head  (Read 10931 times)
Offline MikeM
« on: August 16, 2014, 10:25:54 AM »
changing this head of mine
is it simply a matter of cleaning up faces for the new gaskets ?
also valves after lapping in do the valves have to go back into same place from old head
« Last Edit: August 16, 2014, 01:43:02 PM by MikeM »
Re: changing vales to different head
« Reply #1 on: August 16, 2014, 11:19:08 AM »
Valves need to go in whichever hole they were lapped to. If moving valves from one head to another, they will need lapping to the new head :D :D
Offline Paull
« Reply #2 on: August 16, 2014, 11:49:47 AM »
And just to add when the valves are lapped in fill the crowns with petrol to see if they leak.
If not job done.  :) :)
Paul
S**t Happens
ka-ja
Re: changing valves to different head
« Reply #3 on: August 16, 2014, 06:41:19 PM »
Hi,
     electric drill is quicker!
Offline MikeM
« Reply #4 on: August 16, 2014, 08:30:36 PM »
because its my first time going to use something that easy going, seen the drill video on youtube but don't fancy myself with that
« Reply #5 on: August 16, 2014, 08:41:32 PM »
Electric drill? Bloody cowboys  >:(
Offline MikeM
« Reply #6 on: August 16, 2014, 08:54:32 PM »
from what I can tell once you get a smooth ring on both faces your good to go ?
 also does the part the valve slides into  need to come out ? original head has new stem seals
valve guides ?
« Reply #7 on: August 16, 2014, 10:48:30 PM »
Speaking of that I've found my original Honda CB500/4 valve guide reamer. Not seen it for ages and it was hiding in my Snap On box. As I doubt very much whether I'll ever use this again I may donate it to someone on the understanding they will lend it to whoever needs it.
   Oddjob,
 it might be an idea to have a separate thread, "Special tools for loan"
the user pays postage ,and returns after use
perfect for smaller items
ka-ja
« Reply #8 on: August 17, 2014, 09:39:26 AM »
Hi,
     The electric drill reference was being sarcastic, although I have known one to be used. Slow and steady and not too much pressure, lifting the valve off its seat for a 1/2 turn now and then during grinding is the only way!
« Reply #9 on: August 17, 2014, 10:18:50 AM »
Oddjob, i would take over the reamer if you wanted, i have several heads if i can ever afford the guides!!
« Reply #10 on: August 17, 2014, 10:39:12 AM »
Bryan, it is easier to put K-liners in.
« Reply #11 on: August 17, 2014, 06:09:05 PM »
K liners cost a lot to do mate, oddjob i will send you my address, no rush mate i still have to sort out all my special tools!!, i do have a copy of the common tools list if you would like a scan when i aint rushing back and forth to hospital for the boy!
« Reply #12 on: August 17, 2014, 08:28:37 PM »
Bryan, the last box of 100 K-liners i got from the states was £40.
Offline mickwinf
« Reply #13 on: August 17, 2014, 10:55:06 PM »
what the f is a k liner?
« Reply #14 on: August 17, 2014, 11:05:45 PM »
Mick, in my spare time i do engines for the drag racing boys and we use them because the NOS gas and high temperature  makes the standard valves stick in the valve guides.
A K-Liner is a Bronze bullet valve guide. So if your valve guides are worn you can re-cut and put a bronze bush in.
