Author Topic: Fuel tubes  (Read 11043 times)
Bodd
Fuel tubes
« on: August 26, 2014, 11:37:03 AM »
Where do the two 3.5mm x 600mm fuel tubes go to ? Numbered 4 in the top picture and 2 in the bottom picture.
Offline Drew400
  • 400/4 I restored
Re: Fuel tubes
« Reply #1 on: August 26, 2014, 11:41:49 AM »
Hello Bodd,
I'm no expert, but on my basket case they simply dangled down behind the swing arm as vents, along with all the pipes from the float basins.
I will be able to locate a photo later today if required.
Cheers, D.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Fuel tubes
« Reply #2 on: August 26, 2014, 12:09:12 PM »
Hi Bodd,
See here...http://www.sohc.co.uk/index.php/topic,6954.msg39452.html#msg39452
Top pic... they route over the top of the air intake box & then down over the back of the gearbox casing & between the swing arm.
You've only yourself to thank as you posted said pic!
Simon
Bodd
Re: Fuel tubes
« Reply #3 on: August 26, 2014, 12:32:14 PM »
Cheers guys, I thought they went that way but as they are listed as "fuel" tubes I wasn't 100% sure. Another question about the part I circled in the picture below which has no part number, the part that the fuel pipe connects to is attached to a tube that rotates around the link pipe, on mine it seems very loose (rotates very freely), is that normal or is it a potential leak ?
« Last Edit: August 26, 2014, 12:37:07 PM by Bodd »
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Fuel tubes
« Reply #4 on: August 26, 2014, 12:53:33 PM »
Hi again Bodd,
On my carb rebuild I too noted the rotation .... would never have described it as 'very loose' but 'exactly as I'd expect' given the o rings nipping it into its carb housing. Certainly it'd never rotate under its own weight + fuel tube, but rather adjust nicely to its most comfortable position & stay there.
You got the correct sized 'o' rings?
Simon
Bodd
Re: Fuel tubes
« Reply #5 on: August 26, 2014, 02:31:11 PM »
I thought it was in two separate pieces like in the drawing below but after stripping it down I found it's not, it's one solid piece with 2 O rings on each end ( it's a long time since I rebuilt the carbs), I've changed the O rings for some new ones and now there is quite a bit more resistance when I move it.
Offline Drew400
  • 400/4 I restored
Re: Fuel tubes
« Reply #6 on: August 26, 2014, 03:11:05 PM »
Can I slightly hi-jack your thread by asking if the piece shown as no. 108 in your diagram is designed to simply act as a balance between carbs (i.e. sharing air/fuel vapour rather than liquid fuel)?
Thank you, D.
Bodd
Re: Fuel tubes
« Reply #7 on: August 26, 2014, 03:20:51 PM »
Thank you, D.
In the parts list it's called "tube, fuel, 2.5 x 16", I don't think it carries liquid fuel as the part circled below does that.
« Last Edit: August 26, 2014, 04:02:05 PM by Bodd »
Offline Drew400
  • 400/4 I restored
Re: Fuel tubes
« Reply #8 on: August 26, 2014, 03:25:29 PM »
Me too thanks.
I'm doing a similar job now on my carbs. I think I finished putting them back together yesterday and will one day put them on an engine.. that's the next big sub-project in my money pit heaven!
Cheers, D.
Bodd
Re: Fuel tubes
« Reply #9 on: September 02, 2014, 11:35:25 AM »
Not a fuel tube but not worth starting another thread, as I am using K&N pod filters where do I route the breather tube (331 in the picture) ? I still have the filter box on the bike but there won't be a filter in it.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Fuel tubes
« Reply #10 on: September 02, 2014, 11:49:38 AM »
Hi Bodd,
There ought to be a frame clip on the spine bottom; from here how's abouts simply clipping / tying it to the RHS frame downtube forward of the battery and thence between the gearbox & swing arm to vent to atmosphere. Don't have the bike nearby... just a guess.
Whatever you do remember oil (mist) will be trying its hardest to coat your back wheel.... so ensure the vent is offset & pointing outboard as far as possible.
750 chaps... doesn't one model vent from 1/2 down the swing arm? Or did I dream that?
Simon
« Last Edit: September 02, 2014, 11:54:59 AM by Lobo »
Bodd
Re: Fuel tubes
« Reply #11 on: September 02, 2014, 12:17:39 PM »
I was thinking of refitting the chamber breather and attaching it to that but I thought it might be spraying oil mist into the empty filter box, preferable to spraying it on the back tyre but still not good, I might just get a filter and use the proper route and connection.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Fuel tubes
« Reply #12 on: September 02, 2014, 02:07:40 PM »
Slight glitch with venting to the empty filter box is that the mist is not being sucked back into the air manifold box / reingested into the engine... and so will have to go somewhere else. And thus it would likely pool into liquid oil, and thence exit down the necessary vent / drain tube.... and out ahead of the rear wheel. Possibly a worse situation...
On the flip side bike crankcases have vented directly to atmosphere for decades; and often likely ahead of their rear wheels.
No one's verified yet, but I'm pretty sure one of the later K (750) models vented some way down the swing arm.
Bodd
Re: Fuel tubes
« Reply #13 on: September 02, 2014, 02:58:28 PM »
Thanks for that Simon, I think the best idea is to make a guide clip to hold the end of the tube so it points out of the side away from the wheel.
Offline Dan
Re: Fuel tubes
« Reply #14 on: September 02, 2014, 05:59:48 PM »
If you're keeping the original filter box you could route the hose to a catch tank with a filtered vent hidden within said box. May need a longer hose but that would make periodical emptying of the catch tank easier. Looking at your RD and CB blogs I would imagine you could do this quite easily and there's no risk of oil mist getting on the rear tyre.
1994 GSXR750WR Endurance rep
1975 CB400F ongoing project
