Author Topic: Fuel tubes  (Read 11046 times)
Bodd
Re: Fuel tubes
« Reply #15 on: September 02, 2014, 06:08:42 PM »
If you're keeping the original filter box you could route the hose to a catch tank with a filtered vent hidden within said box. May need a longer hose but that would make periodical emptying of the catch tank easier. Looking at your RD and CB blogs I would imagine you could do this quite easily and there's no risk of oil mist getting on the rear tyre.
Good plan  8)
bike-pusher
Re: Fuel tubes
« Reply #16 on: September 02, 2014, 09:19:02 PM »
I was thinking of refitting the chamber breather and attaching it to that but I thought it might be spraying oil mist into the empty filter box, preferable to spraying it on the back tyre but still not good, I might just get a filter and use the proper route and connection.
The rocker box breather is simply vented to atmosphere - there's a circular clip for it at the bottom of the frame.
Bodd
Re: Fuel tubes
« Reply #17 on: September 02, 2014, 09:38:31 PM »
I don't think it is, it goes to the chamber breather connected to the bottom of the air box where clip number 1 is shown in the picture below, the drain tube number 27 goes to the bottom of the frame.
« Last Edit: September 02, 2014, 09:40:10 PM by Bodd »
bike-pusher
Re: Fuel tubes
« Reply #18 on: September 03, 2014, 07:18:06 AM »
Sorry, yes, you're right.  Brain fart.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Fuel tubes
« Reply #19 on: September 03, 2014, 03:16:21 PM »
Hi again Bodd,
This is what I was looking for.... The CB750 K6 breather routing.
Cheers,
Simon
Bodd
Re: Fuel tubes
« Reply #20 on: September 10, 2014, 07:14:16 PM »
As it is a cafe racer the seat is no longer on a hinge so if I make a catch tank I will have to remove the seat periodically to check and empty the contents so maybe a longer tube might be a better option, I bought 2 metres of tube and will see what it looks like fed towards the rear of the bike like in Lobo's picture.
Offline Dan
Re: Fuel tubes
« Reply #21 on: September 10, 2014, 11:08:19 PM »
The simplest ideas are usually the best 👍
1994 GSXR750WR Endurance rep
1975 CB400F ongoing project
