Author Topic: It has arrived!  (Read 61297 times)
Re: It has arrived!
« Reply #75 on: September 14, 2014, 07:43:40 PM »
In your last picture you can see the air screw. It is too the right of the T pipe if you look at the picture. It has a brass head and when you remove it there will be or should be a spring. One per carb.
Offline JustcallmeMrT
Re: It has arrived!
« Reply #76 on: September 14, 2014, 07:48:39 PM »
Got it.  So, I should remove the air screws, the T pipes and those tubes from between the carbs, anything else?
Re: It has arrived!
« Reply #77 on: September 14, 2014, 07:57:12 PM »
Do you have the brass tubes out??? They will have little holes down the sides.
Re: It has arrived!
« Reply #78 on: September 14, 2014, 07:58:18 PM »
Yep, got them out.
Re: It has arrived!
« Reply #79 on: September 14, 2014, 08:03:02 PM »
The brass screws from the float bowls??? If that is it they should be ready for a dip. Take the bank of carbs, the bowls, the tops and everything you have removed to be cleaned. Then all you have to do is put them back together. Polish the bowls and tops. And set the float height which is 22mm on those.
Re: It has arrived!
« Reply #80 on: September 14, 2014, 08:03:57 PM »
Thanks Trigger,  you've been a huge help!
Re: It has arrived!
« Reply #81 on: September 14, 2014, 08:05:36 PM »
I should of said, send me the carbs with the fitting kit and £100 and i will do the rest ;)
Re: It has arrived!
« Reply #82 on: September 17, 2014, 07:47:19 PM »
I would not advise someone to take these apart unless they know what they are getting into. There are so, so many little parts to them. But, you can get them apart to change the 0'rings in the T pipes by taking the 8 big cross head screws out of the big alloy rail that holds them together.
Another carb question.  Measuring the o-rings on the T pipe, looks like they're 12mm OD, 8mm ID and 2mm thick.  Is this right?  Would a set of nitrile rings of this size be the correct replacement?
Re: It has arrived!
« Reply #83 on: September 17, 2014, 08:49:22 PM »
You should of got the O'rings in the carb kit. Are you saying that DSS did not put them in???
Re: It has arrived!
« Reply #84 on: September 17, 2014, 09:00:57 PM »
As far as I can see, they are not there... All the bits for each individual carb, but not for the T - tubes between them.
Re: It has arrived!
« Reply #85 on: September 17, 2014, 09:08:21 PM »
I am not in the UK at the moment so can not give you the right measurements. I use Viton O'rings but, you will need something that is fuel resistant. Just looked up a carb kit from Japan and it comes with the O'rings>>     http://www.ebay.co.uk/itm/74-76-HONDA-CB550K-CB550F-CARB-REPAIR-KIT-SET-OF-4-REPAIR-KITS-INCLUDE-CI1220-/251460221180?pt=UK_Motorcycle_Parts_13&hash=item3a8c3278fc
Does the carb kit from DSS not look like this?
Re: It has arrived!
« Reply #86 on: September 17, 2014, 09:13:36 PM »
Nope, missing some of those O-rings.
http://www.davidsilverspares.co.uk/graphics/parts/PCRK%20CB550F_large.jpg
Re: It has arrived!
« Reply #88 on: September 17, 2014, 09:30:39 PM »
Good god, that kit from Japan has more bits and is half the price!  Half a mind to return the DSS kits and order those in the link you sent.
Re: It has arrived!
« Reply #89 on: September 17, 2014, 09:37:21 PM »
If you rush, it will cost you more. Take your time ;)
