Author Topic: Points loom solder tags.  (Read 3642 times)
« on: September 16, 2014, 03:44:59 PM »
Anyone know if the 'D' shaped solder tags on the points loom on Honda's should be the open hole type or the fully closed type. Can't find any replicas so thinking of having some laser cut from brass sheet and then plated although probably no need as I am bound to have some old ones somewhere. Obsession again.. don't ask just take pity  :'(
Cheers ... AshD
Online Bryanj
Re: Points loom solder tags.
« Reply #1 on: September 16, 2014, 05:30:15 PM »
My aged memory tells me i seen both so that don't help at all tho' I think the older twins were closed----maybe perhaps
« Reply #2 on: September 16, 2014, 06:19:17 PM »
With Bryan there remember both types but got no dates when and  the open type I think were later cos they were easier to change without taking them to bits and losing the insulators all over the bench
Bitsa
bike-pusher
« Reply #3 on: September 18, 2014, 07:36:40 AM »
Pretty sure all the ones I've played with have been open.
« Reply #4 on: September 18, 2014, 06:21:22 PM »
CB250/350 K are evidently the  closed type according to a reliable source. Maybe its the fours that had the open type. I know the early twin bikes had high temperature blue & yellow glass braided inner insulation  wire to the points wires  but the fours had high temperature PVC type.
Cheers ... AshD
