Author Topic: Swingarm bush  (Read 5640 times)
Offline ted_paper
Swingarm bush
« on: September 21, 2014, 08:46:06 PM »
Hi,
I will have to be replacing the swinging arm bush pretty soon and have a couple of questions.
Is it worthwhile trying to find the bronze ones that I've read about or are DSS pattern replacements fine?
I've also read that the "collars" may be worn and that these are no longer available - I've tried to find the part numbers for these but can't see them on my parts list - can anybody help identify these?
Re: Swingarm bush
« Reply #1 on: September 21, 2014, 08:59:52 PM »
DSS pattern bushes are as good as genuine, but, bronze bushes are far superior. The collar you are referring to is the long tube that is inside the bushes in the swing arm
Re: Swingarm bush
« Reply #2 on: September 21, 2014, 09:01:47 PM »
Not sure what you are on about with "collars". There is only one collar with part number 52141-361-000. Bronze bush is the best.
Re: Swingarm bush
« Reply #4 on: September 22, 2014, 08:32:48 AM »
You are correct in that the collar is NLA BUT it is not that difficult to get it reground circular and then have a pair of bronze bushes made with a slightly smaller hole to compensate----then grease it every 1,000 miles or once a month so it don't wear out again!!
Offline ted_paper
Re: Swingarm bush
« Reply #5 on: September 22, 2014, 12:36:26 PM »
Thanks for the replies...looks like bronze wins :)
