Author Topic: Starting the engine  (Read 56368 times)
Offline El__burro
Starting the engine
« on: October 04, 2014, 12:43:25 PM »
I am curious to see if the engine is in working order (and mainly want to hear it roar)
Is there a way to start it without mounting all the bits and pieces ie coils end the rest of the wiring diagram.
In other words what is the minimum necessary to start it?
Re: Starting the engine
« Reply #1 on: October 04, 2014, 06:54:47 PM »
1st you need coils then battery,Then a  positive feed to the coils and points which means you need wiring from the points to the coils.When you have it right the points will spark and so should the plugs
In case of any problems air leaks crap carbs if she revs  like hell you need to disconnect the positive feed bloody quick.
Do not think its worth the risk but easy for me I love electrics
Hope this helps, it for me is easier to do it than explain it
Bitsa
Offline El__burro
« Reply #2 on: October 04, 2014, 09:26:35 PM »
Thanks for the reply.
The wiring seems to be there I have a rectangular plug coming out from the engine, then I have the rest of the wiring aside. I need a battery any recommendations for this
« Reply #3 on: October 04, 2014, 09:30:28 PM »
In My opinion get a gel battery seem to be for me great and you get rid off a tube that spews acid on your gorgeous exhausts
Bitsa
« Reply #4 on: October 04, 2014, 10:09:29 PM »
I'll go along with Bitsa as to wiring it, but would add that you may need an oil pressure light as well and try to get oil pressure with the plugs out before you try to run it.
Oh and something halfway sensible for oil condition or you risk damaging it.
Offline El__burro
« Reply #5 on: December 07, 2014, 11:50:59 AM »
My idea was to remove the engine from the frame.
Since i have not much linking it to the frame, as mentioned the wiring is unplugged (and seems to be completed)
I am just trying to get enough to start a bench test.
Fuel, oil, battery and so on.
Is there a link to explain what is needed exactly.
El__burro
Offline El__burro
« Reply #6 on: January 10, 2015, 03:58:52 PM »
Almost there, i have purchased oil and a battery, electrical harness is as new and complete. Just waiting for a good sunny day to attempt.
I am not sure about the condition of the engine inside and i was thinking to flush it somehow...
How?
« Reply #7 on: January 10, 2015, 04:06:01 PM »
I would at least take the sump off and check out the pump.
Offline El__burro
« Reply #8 on: January 10, 2015, 05:02:47 PM »
Out of boredom i have removed the oil sump bolt to check for oil.
Actually almost a litre came off it. Then I tried to add more but it would not go through the engine and out again. It stays in the oil tank. Is this normal? I guess that is what the pump is for.
How much oil do i need to add (from zero) to ensure no damage is done.  Bear in mind that I just want to hear it roar.
« Reply #9 on: January 10, 2015, 05:12:58 PM »
Just because it has oil coming out of the sump. How do you know if the pump is working and the strainer is not blocked ?
If you have no oil feed to the top end, the cam will not last very long.
Have you kicked it over until the oil light has gone out ?
Opp's for got: Oil capacity is 3.5 ltr with 2ltr of that in the tank. Pump likes to be primed.
« Last Edit: January 10, 2015, 05:19:31 PM by Trigger »
« Reply #10 on: January 10, 2015, 08:24:33 PM »
Do what Trig says I would and do
Bitsa
Offline Green1
« Reply #11 on: January 10, 2015, 08:34:36 PM »
Bitsa
Baa-aa  ;D
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Norniron
« Reply #12 on: January 10, 2015, 08:45:54 PM »
Bitsa
We know,we know
1977 400 cafe
1972 500/4
2013 triumph STR675
« Reply #13 on: January 11, 2015, 09:57:01 AM »
Good Oh ;D ;D
Bitsa
Offline El__burro
« Reply #14 on: January 11, 2015, 10:01:49 AM »
Probably today i will remove the oil sump, but how can I tell if the pump works without power?
What wattage is the oil warning light?
El__burro
« Last Edit: January 11, 2015, 10:15:28 AM by El__burro »
