Author Topic: Switchgear Wiring Route  (Read 8738 times)
Offline Lynx
  • Repair & Despair Under One Roof
« on: October 04, 2014, 05:09:24 PM »
Hi all,
I fitted my newly chromed handlebar today. This is a genuine one with the holes in for the switch wires. The one it is replacing is a pattern without the holes. So I routed the wires inside the bar OK but when I came to fit the switchgear, I found it a bit awkward. I thought the wires would route from inside the switch block straight into the handlebar holes but they didn't want to do that. Have a look at the photos attached and see if you think that is right.
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Re: Switchgear Wiring Route
« Reply #1 on: October 04, 2014, 06:45:31 PM »
Lynx
They go on further than that you do not see any wiring and also there should be a pin that locates in the handelbars
Bitsa
Offline Lynx
« Reply #2 on: October 04, 2014, 07:10:53 PM »
Ah crap! I was afraid you were going to say that. That means the metal on the left and right blocks has been broken out to allow the cables to be routed on the outside of the bar. The pins are missing too .
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #3 on: October 04, 2014, 07:29:53 PM »
Lynx
All is not lost you can use a decent sized rivet for the pin providing the hole is there in the bottom half and once you have it located you can patch the hole maybe with jb weld or similar?and paint it only you would know whats been done
Bitsa
Offline Lynx
« Reply #4 on: October 04, 2014, 07:39:29 PM »
Yes that'll be do-able. I've even got spares but they've been butchered too!
« Last Edit: October 04, 2014, 07:41:04 PM by Lynx »
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline PDAY
« Reply #5 on: October 05, 2014, 05:32:18 PM »
Lynx, I've got a pair of old switches in the garage somewhere, electrics wise they are a bit past their best but if you after the casings they would be good donor parts. let me know if you need them and I'll dig them out in the week and confirm that they're intact. cheers Paul    :)
Offline Lynx
« Reply #6 on: January 21, 2015, 10:47:17 PM »
I went with Bitsa's advice and filled the hole with metal filler. Before, filled and painted.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #7 on: January 22, 2015, 05:58:44 PM »
They have also had the bottom halves cut to let the wires out
Offline Lynx
« Reply #8 on: January 23, 2015, 03:15:46 PM »
Yes. that's the point on the thread  ;).
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #9 on: January 23, 2015, 07:01:53 PM »
Nice job
I do not remember any of the 750k models having surface run wiring except that crap on/off switch
Bitsa
Offline martin_uk
« Reply #10 on: February 08, 2015, 10:58:32 AM »
Nice job
Bitsa
K8 does, as has connector block. :P
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #11 on: February 08, 2015, 06:41:47 PM »
Martin
You are well right but I have never worked or seen a k8 apart from photos.Am I right in saying they did not appear in the UK?All I recall is k6 k7 f1 f2.Still dont like surface run wires though
Bitsa
