Author Topic: Speedo Reset Knob  (Read 5585 times)
Offline dawmallard
Speedo Reset Knob
« on: October 07, 2014, 09:07:05 PM »
Hi - any of you guys got a spare little black knob that resets the mileometer on the side of the speedo or know of a scource?
Regards, David
Proud to be an old fashioned postie
Bikes - Honda 550K3
           BMW R100RT 1996
Offline Drew400
  • 400/4 I restored
Re: Speedo Reset Knob
« Reply #1 on: October 08, 2014, 11:04:35 AM »
Hi David,
I posted a similar request a while ago and received back the suggestion to use a glue tube stopper or some such (I think UHU or Araldite glue caps might fit the bill). I still have a bald knob, so to speak, pending the completion of the re-build for which this item may be the last and final crowning glory!
Hope that helps,
D.
Offline Ian DB
« Reply #2 on: October 08, 2014, 01:16:51 PM »
you could try 750faces.com who stock them, I needed one for the which comes out of the rear of my speedo. Not sure if the part is the same for side entry clocks though. In the end, as they aren't cheap I made one on my lathe instead
Hope this helps
http://www.cb750faces.com/cb750faces.nl/en/11-honda-cb750-laverda-gauge-parts
Offline dawmallard
« Reply #3 on: October 08, 2014, 02:34:17 PM »
Thanks for the replies - it's always the little bits that seem to be the problem....
David
Bikes - Honda 550K3
           BMW R100RT 1996
« Reply #4 on: October 08, 2014, 04:52:11 PM »
I may have one. Will have to go hunting.
Offline matthewmosse
« Reply #5 on: October 08, 2014, 05:45:24 PM »
As a long shot if there is a breakers by you who get the real wrecks in then it might be worth looking for a crashed old superdream with dammaged clocks, they might not be ok with you sabotaging a good set of clocks but superdreams and a fair few other bikes used very similar clocks and I have in the past robbed bits out of superdream clocks to fx my 500/4 ones.
