Author Topic: It lives!  (Read 11478 times)
Offline UK Pete
Re: It lives!
« Reply #15 on: October 12, 2014, 10:10:03 AM »
Nice one fella
pete
Re: It lives!
« Reply #16 on: October 12, 2014, 02:44:50 PM »
When I was young(er), the test was whether you could "kick" it over by hand...
 :D
Offline JustcallmeMrT
Re: It lives!
« Reply #17 on: October 12, 2014, 02:48:50 PM »
I'll have to try that next time it's together.  As if is, I spent last night stripping it all back, getting ready to remove the engine and start prepping the frame.
Re: It lives!
« Reply #18 on: October 12, 2014, 04:26:24 PM »
The easiest way to get that out the frame is to remove the sump, oil filter and lay it on something soft on its side.
Re: It lives!
« Reply #19 on: October 12, 2014, 04:27:24 PM »
Should I pull the forks first?
Offline Green1
Re: It lives!
« Reply #20 on: October 12, 2014, 04:30:13 PM »
Trig do you have to lay it on its right side like the 750 if so don't forget to remove the points cover if its any good
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Re: It lives!
« Reply #21 on: October 12, 2014, 04:32:22 PM »
Mick
From the looks of it, most of the bolts will have to pull out from the right, so I think it'll have to be on the left.  Don't know if this is typical or just the way the P.O. assembled it.
Offline matthewmosse
Re: It lives!
« Reply #22 on: October 12, 2014, 04:41:33 PM »
Definitely has to come out of the right side of the frame, the engine bracketts only let it out that side. Note the bracket that holds the cluch cable on top right of gearbox, it comes off, on the left that long bolt goes through the frame so it will not fit through from that side.
Re: It lives!
« Reply #23 on: October 12, 2014, 04:44:08 PM »
Thanks for the tip Matthew, would have spent am age trying to pull it out the left side.
Re: It lives!
« Reply #24 on: October 12, 2014, 04:56:44 PM »
Yep, folks off. The less you have, then the lighter it is to lift the frame from the engine.
