Author Topic: Winter Work  (Read 45256 times)
Re: Winter Work
« Reply #75 on: December 21, 2014, 03:58:48 PM »
Trig
Apart from what you said is there any other differences for that year?
Bitsa
In the engine ? No. The cam washer has never been on any microfiche for the 400 that i can find. Can't even find a part number for it but, if i have found one on a re-build i put it back.
Offline hondatri
Re: Winter Work
« Reply #76 on: January 14, 2015, 04:14:26 PM »
I was getting my Exhaust ready for fitting and discovered that the Lip on tthe Engine end (Pushes on gasket) was missing found it on garage floor going to get a mate to mig weld it back on fingers crossed. Dont want to buy a pipe
Offline hondatri
Re: Winter Work
« Reply #77 on: January 19, 2015, 08:01:44 PM »
 I dealt with Dennis at noxandrattles who supplies Stainless Parts for 400/4 He told me he had stripped lots of 400/4 engines and never came across a washer on the camshaft, Today he contacted meto let me know he was doing the Topend of a 400/4 and lo and behold there was a a washer on the camshaft.
Re: Winter Work
« Reply #78 on: January 20, 2015, 04:57:26 PM »
Could it be a spacer shim, so only there if needed?
Re: Winter Work
« Reply #79 on: January 20, 2015, 05:23:51 PM »
What do you mean by a washer on the cam?  The two bolts that hold the gear onto the camshaft don't have washers,  if they're there then somebody non-Japanese has put them there
Re: Winter Work
« Reply #80 on: January 20, 2015, 06:54:20 PM »
Mike
It is not washers on the 2 bolts its like a second shim almost the same size as the cam sprocket
Bitsa
Offline hondatri
Re: Winter Work
« Reply #81 on: January 20, 2015, 07:11:54 PM »
Its all in the terminology guys. Washer/Shim it appears on very few engines apparently. Why I dont know
Re: Winter Work
« Reply #82 on: January 20, 2015, 07:54:18 PM »
Same here wierd
Bitsa
Re: Winter Work
« Reply #83 on: January 20, 2015, 07:57:38 PM »
Because someone set the machine wrong, so a shim was needed to correct the mistake ;)
Re: Winter Work
« Reply #84 on: January 20, 2015, 07:58:33 PM »
Nice thought and probably right there mate ;)
Bitsa
Re: Winter Work
« Reply #85 on: January 20, 2015, 08:00:46 PM »
Bitsa
You will find it on a run of engine numbers ;)
Re: Winter Work
« Reply #86 on: January 20, 2015, 08:07:18 PM »
Yeah believe that too
Bitsa
Offline hondatri
Re: Winter Work
« Reply #87 on: January 27, 2015, 07:33:15 PM »
Getting there with the Old Girl. Got the Carbs on today with help from my Son. Two heads and four hands are best.
