Author Topic: clocks ratio  (Read 2726 times)
Offline steven400/4
clocks ratio
« on: October 24, 2014, 11:01:19 PM »
does anyone know the speedo and rev counter ratio,s for a honda cg125 or how to work it out  :'( :'( :'( :'(
cb400f2 x7
honda ss 50
gsx 1400
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: clocks ratio
« Reply #1 on: October 25, 2014, 01:33:24 PM »
Hi Steven,
Until a Tec guru comes up with the figures can I simply suggest you get out on a straight piece of road with a GPS taped to the tank. In each gear hold a steady speed & note the two readings... you'll now have said ratios.
Your speed will be (likely) more accurate than the original speedo gave, and best, independent of tyre size.
Simon
Re: clocks ratio
« Reply #2 on: October 25, 2014, 05:32:14 PM »
Sometimes it is printed on the back of the clock.
Offline steven400/4
Re: clocks ratio
« Reply #3 on: October 25, 2014, 07:01:44 PM »
thanks gents i,m building a cafe racer for my lad most of the speedos i have looked at say 2.1 ratio but the taco,s say 1.4 or 1.7 i no taco dont matter that much but would be good to get the speedo right  8)
cb400f2 x7
honda ss 50
gsx 1400
