Author Topic: identifying handlebars  (Read 5984 times)
Offline wolfheze
« on: October 27, 2014, 07:25:18 AM »
Hi, I am trying to establish if a pair of handlebars that came with my k2 are original North American spec. They measure 30 inches across with a rise of around 8 inches, they have an oval hole in the centre and one at each end for routing the wiring and are capped off at each end with plastic inserts. Any ideas?
Thank you.
Re: identifying handlebars
« Reply #1 on: October 27, 2014, 08:04:26 AM »
With that rise they definitely aint UK spec
« Reply #2 on: October 27, 2014, 08:07:42 AM »
Thank you.
A little confused here. You have this post under 500/550 but, speak of a K2 ?
Offline wolfheze
« Reply #3 on: October 27, 2014, 08:36:01 AM »
Did they not make a 550 k2?
Offline wolfheze
« Reply #4 on: October 27, 2014, 08:42:16 AM »
The rise sounds more than it is. From the first to the second bend is around 5 inches, 8 inches is from the centre section to the ends
« Reply #5 on: October 27, 2014, 08:45:39 AM »
Yep, Introduced late 74 to the USA only. Most original bars do not have plastic ends but, you can tell original bars if the switch gear fits without the wires being pinched as they go in the holes.
Offline wolfheze
« Reply #6 on: October 27, 2014, 09:14:33 AM »
Ok, guess i will only find out when i come to fit them, seems i am going against the grain refitting higher bars but  having lower shorter ones means all the cables are too long, plus theres no point trying to go quickly on these things, might as well be sat up in the breeze!
