Author Topic: Inlet manifold o ring query?  (Read 5156 times)
Offline simonster
« on: November 06, 2014, 04:59:47 PM »
I'm replacing the hardened o rings which air seal the carb manifold to the head. Will I need the hi temp viton o rings or will the standard rubber ones be ok. I'm guessing the running temp of the head is about 200degs and I don't fancy removing burnt rubber once they gone past their temp range!!.  I've not tried to source them through DS as they aren't shown in their drop list and doubt they will supply.
Re: Inlet manifold o ring query?
« Reply #1 on: November 06, 2014, 05:02:34 PM »
Go for the viton ones. Take the measurement and order them on fleabay cheap.
« Reply #2 on: November 06, 2014, 06:26:45 PM »
Same O ring as the rocker caps
Offline simonster
« Reply #3 on: November 07, 2014, 07:49:52 AM »
Cheers guys. Have ordered them as suggested and yes just realised they match the rocker caps :-))
